First board tests
A project log for LoRaNicator
A wireless telecommunications device, based on LoRa technology, that receives and displays alphanumeric messages.
5volt-junkie5Volt-Junkie • 03/04/2019 at 16:13•0 Comments
Started testing the hardware. Need another On/Off-controller since the current model allows only 2 seconds time frame for the feedback from microcontroller and the SAMD21 with Arduino bootloader needs ~2.5 seconds for booting and setting the GPIO to High.
 Following initial tests passed (tested with example codes)
 - RFM95 module
 - I2C RTC (fixed a mistake in routing of I2C. SDA and SCL were swaped :(  )
 - uSD-card
 - LiPo charger
 - programming over USB
Next steps:
- order some missing parts (capacitors for the display)
- test display :-)
