Credit, where it is due.
A project log for Minimalist Li-Ion Discharger/Capacity meter.
What you need to grade your scavenged cells for building balanced packs.
daren-schwenkeDaren Schwenke 01/29/2019 at 20:540 Comments
I started with someone else's code and wiring first.  I went back and found that project, so I could include it here now.   https://www.instructables.com/id/DIY-Arduino-Battery-Capacity-Tester-V10-/
There is not much in the original code that has stayed the same, but starting with something working was a head start. I still need to attribute it yet.
