Seems to work..
A project log for Minimalist Li-Ion Discharger/Capacity meter.
What you need to grade your scavenged cells for building balanced packs.
daren-schwenkeDaren Schwenke 01/29/2019 at 13:190 Comments
I've now discharged 32 cells!
3 were 'bad' with a capacity below 200mAh.
Some were in the 1500mAh range.
The majority came in between 1800mAh to 2300mAh.
Some were from before I calibrated properly and were cycled again.  They all went up in capacity a similar amount.
I've also tested several post-calibration cells twice to check consistency.  They all went up in capacity between 80-150mAh on the second charge/discharge cycle.  I'm assuming this was the result of bringing them back from ~2.8v and that they are regaining some capacity by being cycled.
<EDIT>  I cycled two of these consistency check cells one more time.
The first one reported 3mAh higher capacity.  The second one reported 42mAh higher.
That is way more consistent than I expected.  I'll take it.
</EDIT>
I've also moved the same cell between discharge slots and so far the numbers look good.
