Everything old is new again.
A project log for Minimalist Li-Ion Discharger/Capacity meter.
What you need to grade your scavenged cells for building balanced packs.
daren-schwenkeDaren Schwenke 02/06/2019 at 18:540 Comments
Still continuing to cycle the cells a second time.  Still all going up in mAh value, save one which went down 30mAh.
10 cells left to do.
Ordered some Li-ion charger PCB and 18650 battery holders from Amazon.  Both were 10 for $9, and will let me charge 10 at a time, at 1A.  That should give me some more options for cycling cells I'm questioning, without being so darn slow.
<EDIT>  Cell charger done.   I wish I had done that way sooner... </EDIT>
Also built a cell welder and tested it.
Works well, but you have to be careful to keep the pulse duration short, as shown on my test cell here where I burned through.
