Initial post
A project log for VisualK-OS (v5.0)
rPi/Arduino-Powered Multi-Component Stage Lighting/FX System
kevin-slaughterlord-k-osKevin Slaughter/Lord K-OS 01/28/2019 at 10:070 Comments
The software currently has functioning color configuration and UI elements for both the FBA and Thor devices. Once I have assembled the FBA control circuit, I will begin COMMS (serial) module implementation, as I would prefer to design the new circuit first and then make the code work with that, as opposed to the other way around.
