My first Fursuit - Yes I am a Furry
This project will showcase the process of my making my first fursuit from scratch. This will be a long rocky road that needs to be shared.
The above image by Screwbald "Here's looking at you"https://www.deviantart.com/screwbald/gallery/Project logs will include the construction of the head, hands/paws, feet/paws, tail and body suit. I will also include images of actual animals in nature as well as fursuits and drawings/sketches that helped me decide the look of my suit.
This is the current stage in the construction of Marcus.
This is the current state of my fox head base for "Dr. Marcus Foxelhaus".  The digital render by @Morning.Star . "Shaken Not Furred"
Oh, BTW I have placed bifocal lenses into the foam. The frames are just for effect and do look kind of cool.
Lets back up a little first. I attended Anthro Crossroads East 2019 in January and that was my first ever FurCon. I have always enjoyed and admired anthro/furry art since being a child , yes that includes Saturday cartoons in the 60's. My interest in furries and fursuits began to perk up several years ago and after attending my first furcon I was hooked and felt the need to take the plunge and make my own costume/fursuit.
Let me say that I can not draw or sketch. I am also stick figure challenged yet can paint landscapes and draft. Go figure :-)
I was split between fox or rabbit and the foxy side of me won out. I next needed a reference to go by for the look I wanted and chose this clip of art from
www.sketchbook.com - How to draw a fox step by step
I next needed to select a method of construction for the foam base and decided on this furry web site http://fursuit.tanidareal.com/savoy/en/03fmakeheada.htm
This site for "Savoy" has a lot of great information for the making of a entire fursuit.
I decided that I did not want the look of a traditional Red Fox so searched the web for nature images of several other fox breeds and decided on a look and color mixed between a Bat Eared Fox,
And a Arctic Fox in summer fur colors.
  • Adding mouth detail
    Dr. Cockroach03/11/2019 at 22:19 0 comments
    Started adding black felt to the inside of the mouth for Marcus. I also plan on adding a few teeth as well.
  • Adding fur to Marcus
    Dr. Cockroach02/24/2019 at 16:38 0 comments
    First I want to present a video that shows the progress after placing fur onto the Marcus foam base. At this point the ears, eye brows, nose and inside of the mouth need to be finished. I am also going to take my time in trimming the fur to its final look.
    The fur was found at my local Hobby Lobby craft store. One yard of this fur was $19.99. Ten short sticks of hot melt glue was used up to this point.
    What follows is roughly the pictorial steps in the furring process.
    This fur was very dense and it is very hard to find the backing through the fur and the backing is very soft as well. Very easy to work with.
    A sample test patch just to see how it was going to look.
    The taping process. Masking tape was used to build up the fur pattern pieces.
    After taping, the next step was to mark off the pattern cut lines as well as fur lay direction and any marks to assist in final fur placement.
    Carefully cut and remove the pattern pieces ( 5 ) and begin the process of laying them out flat onto paper. If the patterns will not lay out flat then small darts need to be cut into the patterns. Much like laying out a world globe flat.
    Trim the paper backing to match the pattern piece and then begin the process of marking and cutting out the fur. be careful to place the fur in the desired direction so that the fur is laying the way you want. Cut the fur from the backing side using a sharp razor blade. Do not use scissors as they will cut the fur as well.
    The Werewolf look.
    Trim the fur real short for the eye areas.
    Trying to decide if a mustache and goatee will work for Marcus.
  • The Foam Head Base
    Dr. Cockroach02/07/2019 at 11:47 0 comments
    I am just going to present a series of photos that show the progression of making the head base from start to the point that it is ready to be taped. Most of this work was done in about four days of off and on work and I have never done anything like this before. All that is needed material wise is a roll of 1/2" thick foam, a styrofoam model head from the local big box store and a hot melt glue gun.
    The only tool used for cutting and shaping was scissors.
    That's is Pocari Roo online :-)
    Had to test  if I could actually see out of it. My wife was laughing her butt off.
    Setting my bifocal lenses into place.
    Working on the lower jaw.
    Attach elastic straps for wearing the lower jaw.
    Keep trimming the foam until you get the shape you want. If too much foam is removed then more can always be added.
    Just a short video to check for range of motion.
    Test of the lower jaw.
View all 3 project logs
Daren Schwenke wrote 02/19/2019 at 04:02 point
I did a previous build with an articulated, passive mouth, by hinging the mouth as it looked best for the rest of the head.  Then internally I added a chin strap, like the type in football helmets, but with zero stretch.  Very effectively transferred jaw motion to mouth motion.  How far you bias it towards the hinge = how much your motion is amplified.
Daren Schwenke wrote 02/19/2019 at 03:51 point
"Keep trimming until you have the shape you want"  I made the mistake of saying something like that, and someone added... add years of practice and natural talent.  :)
The ability to look at a 3D shape and reproduce it, that is a talent sir.
The ability to look at at 3D shape and change it to match what is in your mind... that is an artist.. sir.
Dr. Cockroach wrote 02/19/2019 at 10:05 point
I just need to stop trimming :-) I still have to tape the entire head and cut away the patterns, cut the fur, sew the fur then glue the fur onto the head. That will cover over very fine details... So I need to stop trimming ;-) But I can't help myself :-D
Bharbour wrote 02/06/2019 at 13:26 point
I like it!
Dr. Cockroach wrote 02/06/2019 at 13:54 point
Thank you, There is going to be some electronic hacking along the way with this fun project as well :-D
Bharbour wrote 02/23/2019 at 23:59 point
A fine opportunity for some fuzzy logic :)
