Hackaday.io Hackaday.io
Sign up Log in
Interactive Door using Makey Makey
Holding the handle of the door and giving it a high five, lights up the word "HI" formed by LED strips
qurat-ul-ain-naqviQurat Ul Ain Naqvi
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
4 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 4
  • Hackaday Prize 2019
View Gallery
Public Chat
432
4
3
7
Team (1)
  • qurat-ul-ain-naqviQurat Ul Ain Naqvi
Join this project's team
hardware
completed project
2019hackadayprize
This project is submitted for
This project was created on 01/30/2019 and last updated 7 years ago.
Description
This is something we did at LearnOBots (where I work) for fun. I used the output signal of Makey Makey to generate a signal whenever anyone completes the circuit by holding the metallic door handle and placing the hand on the aluminum foil cut out in the shape of a hand to light up the LED strip. Pretty simple, right?
Details
Components
  • 1 × Makey Makey
  • 1 × L298 Motor Controller Board
  • 1 × Battery Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • 1 × LED Strip
  • 1 × Aluminum Foil
View all 6 components
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Qurat Ul Ain Naqvi wrote 02/12/2019 at 06:44 • point
Aw thanks.
Actually it is easier on a desk to keep Makey Makey connected to a PC, for a door I know how difficult it is to keep it connected to a computer.
Dan Maloney wrote 01/31/2019 at 15:39 • point
"Speak Friend, and Enter!"
Qurat Ul Ain Naqvi wrote 02/12/2019 at 06:42 • point
Hahah more like "tap friend and enter!"
Selina Zawacki wrote 01/30/2019 at 16:38 • point
Cool! I often see Makey Makey projects on the desk - it's nice to see how you've incorporated it somewhere else in the space.
What happens when you replace the resistor and capacitor of an RC sawtooth oscillator with a reverse biased LED?
Project Owner Contributor
Cadmium-free Light Sensitive Sawtooth Oscillator
bornachbornach
Discrete optocouplers using metal can transistors and 5mm LEDs (and a saw)
stephenStephen
WEMOS D1 mini ESP8266 project
Wi-Fi signal strength LED indicator
dkosDKos_
Official Hackaday Prize Entry
Simple circuit for light show
LED strip flashing to music
mattkomattko
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Interactive Door using Makey Makey", please tell us the reason.
Send message
Remove Member
