MQTT Broker secure setup
Copyright (c) 2019-2023 Warren Taylor.
Here are the basics of how to install, configure, and secure the “Mosquitto” MQTT Broker on an already properly configured and running installation of OpenWRT. However, the MQTT Broker can run on any computer on a local area network (LAN). You could even run it on a Raspberry PI if performance isn’t a strict requirement. So the following instruction should be adaptable to most modern operating systems.
Disclaimer
The following documentation in no way guarantees a secure system.
Install Mosquitto Broker and Client
With ssh (or similar) log into your OpenWRT router.
ssh root@your-router-hostname opkg install mosquitto-ssl mosquitto-client-ssl libmosquitto-ssl
Create "mosquitto" user if it does not already exist
useradd -M mosquitto usermod -L mosquitto
Create a directory to securely hold your certificates
(Keys and Certificates can be generate on any computer as long as the required files are securely copied to the server and all keys are securely stored.)
mkdir /root/mosquitto chmod go-rwx /root/mosquitto chown mosquitto:mosquitto /root/mosquitto cd /root/mosquitto
Creating the MQTT Keys and Certificates
The documentation below talks a lot about Keys, Certificates, Certificate Authorities, etc... Rather than trying to rewrite the very good documentation others have already put a great deal of effort into, I refer you to some of their work:
- SSL and SSL Certificates Explained For Beginners
- Introduction to MQTT Security Mechanisms
- Mosquitto SSL Configuration -MQTT TLS Security
- Securing a Mosquitto Server
NEVER use the same key and certificate to secure more than one device. If one device becomes compromised then all devices secured with the same key and certificate are also compromised. When generating your credentials it is important to use different subject parameters for your CA, server and client certificates. Every time you are prompted for the CN (Common Name), enter your same server hostname. If you don't know your exact hostname then run something like:
uci show system
Create an X509 CA key and certificate for self-signing
(Determine and securely store a PEM Pass Phrase, which is used to protect your CA Key)
openssl req -new -x509 -days 365 -extensions v3_ca -keyout mosq_ca.key -out mosq_ca.crt -subj "/C=CA/ST=BC/L=your-city/O=ca.your-domain.com/OU=ca/CN=your-hostname/emailAddress=your@email.com"
Subject Parameters:
- C - Country
- ST - State
- L - City
- O - Organization
- OU - Organization Unit
- CN - Common Name (eg: the main domain the certificate should cover)
- emailAddress - main administrative point of contact for the certificate
To verify:
openssl x509 -in mosq_ca.crt -noout -text
Generate the MQTT Server private key
openssl genrsa -out mosq_serv.key 2048
Generate the MQTT Server self-signed certificate
openssl req -new -key mosq_serv.key -out mosq_serv.csr -subj "/C=your-country/ST=your-state/L=your-city/O=server.your-domain.com/OU=server/CN=your-hostname/emailAddress=your@email.com"
Generate the CA signed certificate to use in the MQTT Mosquitto Server
openssl x509 -req -in mosq_serv.csr -CA mosq_ca.crt -CAkey mosq_ca.key -CAcreateserial -out mosq_serv.crt -days 365
Generate the MQTT Client private key
openssl genrsa -out mosq_client.key 2048
Generate the MQTT Client self-signed certificate
openssl req -new -key mosq_client.key -out mosq_client.csr -subj "/C=your-country/ST=your-state/L=your-city/O=client.your-domain.com/OU=client/CN=your-hostname/emailAddress=your@email.com"
Generate the CA signed certificate to use in the MQTT Client
openssl x509 -req -in mosq_client.csr -CA mosq_ca.crt -CAkey mosq_ca.key -CAcreateserial -out mosq_client.crt -days 365
Increase the security of the files just created
chmod go-rwx /root/mosquitto/* chown mosquitto:mosquitto /root/mosquitto/*
Mosquitto server config
/etc/mosquitto/mosquitto.conf
port 8883 cafile /etc/mosquitto/mosq_ca.crt keyfile /etc/mosquitto/mosq_serv.key certfile /etc/mosquitto/mosq_serv.crt protocol mqtt tls_version tlsv1.2 require_certificate true
Copy the necessary certificates and key
cp /root/mosquitto/mosq_ca.crt /etc/mosquitto/mosq_ca.crt cp /root/mosquitto/mosq_serv.key /etc/mosquitto/mosq_serv.key cp /root/mosquitto/mosq_serv.crt /etc/mosquitto/mosq_serv.crt
Restart the Mosquitto Broker
service mosquitto stop service mosquitto start
Run a quick test
The following command should turn on zone 2 for 2 minutes (i.e. 120 seconds). Try running it now, even if the MQTT client has not yet been setup, in order to check for any errors that may occur on the server side.
mosquitto_pub -h your-hostname -p 8883 --cafile mosq_ca.crt --cert mosq_serv.crt --key mosq_serv.key --debug --topic irrigation/zone/on -m "2 120"
Error: The connection was refused.
If you are using a newer version of the Mosquitto Broker
you may get the following error messages:
Client (null) sending CONNECT Client (null) received CONNACK (5) Connection error: Connection Refused: not authorised. Error: The connection was refused.
The quick solution is to update mosquitto.conf with the following line and then Restart the Mosquitto Broker:
allow_anonymous true
However, this solution is a "double edge sword". Sure, it gets things running but you may now be less secure than you require. A more complicated configuration could include:
... allow_anonymous false use_identity_as_username true ...
Or even require user name and password in addition to using security certificates and keys.
There are many more Mosquitto Security related configuration settings but I cannot tell you what to do because everyones security requirements are different and these are getting into complicated configurations that are beyond the scope of this project.
W. Taylor
I am trying to get MQTT working with Weewx Weather app and I use this method, all I get is:
1617708945: Error: Unable to load CA certificates. Check cafile "/etc/mosquitto/certs/mosq_serv.key".
1617708945: OpenSSL Error[0]: error:0B084088:x509 certificate routines:X509_load_cert_crl_file:no certificate or crl found
Is there a reason for this issue?
The documentation above describes the file being in "/root/mosquitto/mosq_serv.key". Check your configuration settings and confirm the files are in the correct directory.
Hi!
How I can resolve this message on publish/subscribe in my Broker:
`SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate)`
What I doing wrong?
I have updated the above documentation. Search for the section containing "allow_anonymous true". Also make sure that you are correctly referencing the mosq_ca.crt file.
Very good, thanks! Please, can you show a example using client certificates? How mqtt client subscrible or publication can use the client certificate?
Thanks!
Go to https://hackaday.io/project/163666/log/159166-secure-esp8266-mqtt-client and refer to the "secure_credentials.h" section.
Or you can open a command shell and go to your directory containing your certificates and keys. Then try running:
mosquitto_sub -h your-hostname -p 8883 --tls-version tlsv1.2 --topic irrigation/zone/on --cafile mosq_ca.crt --cert mosq_client.crt --key mosq_client.key
And then from another shell:
mosquitto_pub -h your-hostname -p 8883 --tls-version tlsv1.2 --topic irrigation/zone/on -m "1 5" --cafile mosq_ca.crt --cert mosq_client.crt --key mosq_client.key
Obviously, replacing "your-hostname" with the actual host name you used when creating the keys and certificates.
