Designing some new Lamps
A project log for ESP32-MeshKit custom RGB LED Lamps
Use this RGB Leds that are in your garage to build your own Lights. As simple as Leds, Ω and soldiering (To be safe max. 30 mA per GPIO)
martin-fasaniMartin Fasani 03/12/2019 at 12:520 Comments
Mini-projector Lamp
8 watts RGB Led only + lens from led-tech.de
Please comment if you are interested in the design and follow this project.
Concrete Lamp refactoring into an ESP-Mesh RGB Lamp with White channel
3 eigth watts RGB + some warm White 5mm leds
