First Tindie mini stage Lamp
A project log for ESP32-MeshKit custom RGB LED Lamps
Use this RGB Leds that are in your garage to build your own Lights. As simple as Leds, Ω and soldiering (To be safe max. 30 mA per GPIO)
martin-fasaniMartin Fasani 04/02/2019 at 05:480 Comments
So if you like the lamp but you are lazy or do not have time to build it here is the first one for sale:
https://www.tindie.com/products/fasani/esp32-mesh-mini-stage-led-lamp-rgb
Printed in carbon fiber and built with detail. But with 25 dollars aprox. You can build it yourself! Even with less if you have some spare Leds and an ESP32. Demo Video:
