ESP32-MeshKit unexpensive RGB LED Lamps
Use this RGB Leds that are in your garage to build your own Lights. As simple as Leds, Ω and soldiering (To be safe max. 30 mA per GPIO)
The Espressif ESP-Mesh took a different approach than Osram or Phillips: Every device is a network member making a Mesh of interconnected devices. There is no gateway because there is no need for one.
There is also a very important point that is very interesting if you are a maker like me. It’s open source. That means you don’t need to buy a 60€ light to test it, you can just go to the ESP-Mesh github repository and download ESP-Mesh-Light example to compile it in one of your existing ESP32 Boards.
Provided that every GPIO supports max. 40 mA in the ESP-32 we will use 30 max to stay in the safe zone and not make our little chip warm.
In my first approach I just built a 6*3 matrix of RGB Leds and documented the aprox. consumption of every line of 6 LEDs (calculated using a 1K Resistance for each 6 Leds)
Red: 2.4 mA *3 -- 7.2 mA
Blue: 1.8 mA *3 -- 5.4 mA
Green: 2.1 mA *3 6.3 mA
--------------- Total 18.9 mA
Work in progress!
This all started when Espressif sent me a white Button that is part of their ESP-MDF examples. The funny part of the history is that I could never register the button in the App. But exploring the Mesh Development Framework I found a light example and my internal "light" flashed. Heck! There is a light ready to compile. And has PWM outputs, and there is an App ready to control it, what can be better than this ?
So actually you have to make the "hardware" part. The software is already done, with the benefit that is open-source, and in the road of creation you can learn a bit more of MQTT*, ESP-NOW and even monitor to see how the light receives this short messages and interacts with them in real time. MQTT messages are lighting fast since they use UDP instead of HTTP that has a lot of headers and would be actually totally over-engineered to use in this scenario.
So actually you need some Leds, any ESP32 board, and the appropiate resistances for each line of Led. I'm not an expert calculating those so this part I leave to the electronic masters here. This way you can build a light for approx. 10 dollars while learning quite a lot in the process and even maybe getting some other cool ideas to do with the ESP-MESH App.
App for Android: https://www.espressif.com/en/products/software/esp-mesh/resources
App for Apple, search in the Ipad or Iphone "ESP-MESH" NOTE: Deactivate the filter only for iPad since the app is released only for iPhones.
LIGHT Source code to be compiled:
https://github.com/espressif/esp-mdf/tree/master/examples/development_kit/light
PWM Outputs
GPIO4 PWM Red
GPIO16 PWM Green
GPIO5  PWM Blue
GPIO23 PWM_BR output ( I used this for White, not sure if is the right one )
GPIO19 PWM_CT output control ( Color Temperature )
Be cautious to respect the max. 30/ top max 40 mA per PWM output. If you need to add more than that then you need to separate the logical outputs from the power outputs.
MQTT a lightweight messaging protocol for small sensors and mobile devices, optimized for high-latency or unreliable networks
10cm-round-lamp-v1.stl
Ready for the Slicer. Print without any supports
sla - 494.52 kB - 02/18/2019 at 22:14
Download
10cm-round-lamp-v1-support.stl
sla - 88.36 kB - 02/18/2019 at 22:14
Download
10cm-round-lamp-v1.blend
BLENDER File. This would be the best to take if you know a bit of Blender
x-blender - 1.23 MB - 02/18/2019 at 22:11
Download
rgb-lamp.blend
Adding the Blender file containing small light (4.2 cm) and large light (10 cm) Im a beginner in 3D design so in case someone can make it better please tell me and add you as a collaborator in the Project
application/x-blender - 1.18 MB - 02/03/2019 at 09:47
Download
lamp-top.stl
3D-model top of the lamp
sla - 1.64 kB - 02/02/2019 at 18:52
Download
View all 7 files
  • 1 × ESP32 Board Any you have, it does not matter what model, the cheapest you find will work
  • 30 × RGB Leds with GND as common for all (Also one Anode for each color) Any amount will be fine take in account that more than 30mA and you need to separate Logic using a Bus chip or transistor
  • 1 × Only IF > 30 mA per color: 74HC125 or similar https://cdn-reichelt.de/documents/datenblatt/A240/74HC125_74HC126%23STM.pdf
  • 1 × Cables if possible Red, Green and Blue To wire all this together
  • 1 × Spare PCB, size does not matter as long as you can modify the case There is a case example in the Files
View all 6 components
  • Idea for a round 10cm diameter RGB Light
    Martin Fasania day ago 0 comments
    Explanation about how to cut the PCB
    https://twitter.com/martinfasani/status/1097197327251587072
    Result :
  • Making some new STL 3D models as a base design
    Martin Fasani6 days ago 0 comments
    I got some nice messages about the Lamp idea and some requests to make some standard designs. I must say I'm not a great designer in 3D-Modelling and just started doing small things mainly for my own stuff about a year ago.
    But anyways since there is some interest I will extend my initial design and make 3 different lines. All based on the fact that most PCB comes with a width of 10 cm:
    •  5*5cm Tiny lamp  |_|
    • 10*5cm Rectangular |__|
    • 10*10cm Circular tube (No idea how to cut the PCB but it should be a way)
    • 10*10cm Square-pusher this will hold at least 70 RGBs of 5mm or about 20 of 10mm (From the top of my head)
    All ready to be sliced and 3D-printed by you or just to order it so someone else prints it in one of this nice 3D platforms like thingiverse
    About  the LEDs I use standard transparent 5 / 10 mm RGB and some warm white and cold white for some lamps. The cool thing is that is your lamp so you can put inside whenever you like, there are no limitations here ;)
    Just keep in mind to separate power from logik with more than 30mA or your ESP32 will warm and possible some GPIOs will need to be buried. Options vary. Will make a dedicated log about this on the next weekends.
  • 40 seg. video demo from 2 Esp-Mesh lights
    Martin Fasani02/11/2019 at 21:25 0 comments
View all 3 project logs
  • 1
    Search components
    Get any spare Esp32 board and prepare to compile. Get some RGB Leds and a spare PCB
  • 2
    Compile the light example
  • 3
    Soldiering
    Build an RGB Led lamp taking in account to add a proper resistance and not passing the 30mA per gpio
View all 7 instructions
