Raspberry Pi HAT, Compute Module, Smaller
A project log for Luxonis DepthAI
Unleashing the Power of the Movidius Myriad X.
BrandonBrandon 09/17/2019 at 21:514 Comments
Hi everyone!
So we've got every last bit of the RPi Compute Module version of DepthAI working, which is exciting.  So now that it's verified, we made the design smaller.  We had it big on the first prototype so that white-wire fixes would be easier... and we're glad we did that!  We ended up with white wires for:
Anyways, these are all corrected, and the revised, now smaller, design was ordered on Friday!  Here's what it looks like (thanks, Altium 3D view):
And now that this is ordered, we turned our sites on another incarnation of DepthAI that we think will be useful.
But, before we dive into that.  Why did we make the Myriad X Module that we made, well, a module?
It's so that we - and you - can easily turn designs that leverage it.  It allows the Myriad X to be used on simple, easy, 4-layer boards (instead of the 8-layer HDI and BGA tolerancing and yielf optimization that's required if you use the Myriad X directly).
So, leveraging this module, here's the HAT that we're working on:
You can see the spot for the Myriad X Module right there on top.  And then on the left are the FFC (flexible flat cables) connectors to connect to camera modules:
That's right, we're making it so the cameras can be mounted where -you- want them.  We'll have some other follow-own Myriad X boards (e.g. non-RPi-specific) that take advantage of this as well.  Oh, and on FFC, think of the Raspberry Pi camera little ribbon cable... FFC is the general acronym for that type of cable.
Speaking of which, here are the camera boards:
OV9282 - 720p global-shutter mono camera use for disparity depth:
IMX378 - 12 megapixel color image sensor, supporting 4K video!
And you can see the FFCs on the back bottom of these respectively:
And as usual feel free to ping us with any questions, comments, needs or ideas!
Cheers,
The Luxonis Team
Brandon wrote 10/14/2019 at 04:18 point
Also I just noticed they mentioned idein.jp!  Missed that before.
Brandon wrote 10/14/2019 at 04:16 point
Hey thanks for sharing this!  And sorry about the delay.  This looks super useful.
I know these guys were/are doing similar, with crazy-promising results:
https://idein.jp/
Excited to check out that API.
Thanks again,
Brandon
BetaMax wrote 10/11/2019 at 00:47 point
Hey guys, maybe this will be interesting for this Raspberry HAT implementation of the Myriad X Module for the last Rasperry Pi 4, check this out!: https://www.cnx-software.com/2019/10/10/py-videocore6-raspberry-pi-4-gpgpu-python-library-videocore-6-gpu/?fbclid=IwAR3RhsA6LBCuzq19WdodDdqkGSOI9wrozXy_hvrtvn5j0ZbA6W7EZkSKSYQ
Brandon wrote 10/14/2019 at 23:46 point
Just noticed that my replies from my phone didn't show up as replies... oops.  Anyways thanks for sharing this!
