• Needs more time!
    moosepr07/29/2019 at 20:30 0 comments
    So I managed to scrape some time together to solder up a prototype....
    ....... And it doesn't work 🙈 think I need to reflow the atmega, but the device shows promise.
    It's super tiny, and could really work 😁
    Super tiny
    Will be updating things when I get it working 😁
  • first draft
    moosepr02/05/2019 at 09:27 0 comments
    So a project is hard to test if it doesnt exsist!! So i knocked up a quick board to test how it all works. Its simply an atmega32u4, 24lc512 i2c flash, and a sexy little IPS screen i have been trying to find a use for. I tried to keep it all as compact as possible so it could easily fit on a keyring
    Once the boards land i will see if they work, then i will share once its been proven to work :)
