Wireless Test With 2 Receivers
A project log for RC AVR Car with 433MHz Modules
Designing a system where multiple cars can be controlled by keyboard via 433 MHz modules and AVR microcontrollers
Alvi AhmedAlvi Ahmed 11/15/2020 at 19:140 Comments
Results
   As can be seen by the video above, I am able to switch between both
   receivers effortlessly and send the appropriate commands.
   The reason why multiple LEDS  are lighting up on RX side is because I
   implemented the same states for turning on the motor pins as I have
   done when using the varying PWM duty cycle.
