Top Assembly.stlThe outer shell of the gearbox, that slides into the top of the LampBody.Standard Tesselated Geometry - 171.47 kB - 02/04/2019 at 03:02 |
LoxodromeMountingAdapter.stlThe part is the top half of the GearCoreCenter and provides a snap-fit to the Loxodrome.Standard Tesselated Geometry - 165.41 kB - 02/04/2019 at 03:02 |
GearCoreCenter.stlThis part holds the 608 bearing and has the larger 12 toothed gear on the outside. Once the bearing is placed inside, the LoxodromeMountingAdapter is glued into place.Standard Tesselated Geometry - 189.93 kB - 02/04/2019 at 03:02 |
DriveGear.stlThe small six-toothed gear that rotates the GearCoreCenter.Standard Tesselated Geometry - 45.59 kB - 02/04/2019 at 03:01 |
Base Plate.stlThe bottom base piece that holds the motor and sits under the BasePlate.Standard Tesselated Geometry - 132.70 kB - 02/04/2019 at 03:01 |
Motor Adapter.stlA small adapter that allows the DriveRod to connect to the motor.Standard Tesselated Geometry - 85.92 kB - 02/04/2019 at 03:02 |
DriveRod.stlA short drive rod that connects the motor to the gearbox. Slides into the Motor Adapter on one end and into the DriveGear on the other.Standard Tesselated Geometry - 1.45 kB - 02/04/2019 at 03:01 |
Loxodrome.stlThe Loxodrome sphere.Standard Tesselated Geometry - 6.08 MB - 02/04/2019 at 03:02 |
LampBody.stlThe outer body of the lamp that sits atop the Base Plate.Standard Tesselated Geometry - 534.54 kB - 02/04/2019 at 03:02 |
LoxodromeLamp.scadThis OpenSCAD file is the original design for the lamp. Only the LampBody and Loxodrome are retained in the new design, all other parts are replaced.scad - 10.46 kB - 02/04/2019 at 03:02 |
TheSpiralLamp.FCStdThis is the FreeCAD document with the parts for the replacement gearbox.fcstd - 4.50 MB - 02/04/2019 at 03:02 |
