Version 1, kinda.
A project log for [mUPS] Minimal UPS for Raspberry Pi
A short hold-up UPS with automatic safe shutdown and reboot
paul-crouchPaul Crouch 04/11/2019 at 18:170 Comments
I'm calling it version 1 with the intention of revisiting it to address some lose ends and make some improvements. Version 2 will come when I need a longer hold-up, rather than the (almost) immediate shutdown.
You can find my excuses elsewhere as to why it's taken so long and why this documentation is a bit thin, but here's the short version of events:
Twenty-third-time lucky?
UPS diagram (not showing GPIO potential divider!)
Arduino
3 - RPi_UP (DI), RPi GPIO output - high after boot, low just before complete shutdown.
2 - RPi_SD (DO), RPi GPIO input - active-high to trigger shutdown of RPi (through pot.div; 5V >> 3V3).
Not Used: A0 - ADC to 18650 battery, 4V - disconnect load from battery when voltage drops.
4 - Main Power present/not present (DI).
Not Used: 5 - Keep alive/immediate select switch (DI)*
6 - Relay (DO) - active-high opto-isolated (N.O. contacts). Opens to disconnect battery.
7 - Amber UP LED.
8 - Red SD LED.
9 - Green MPP LED.
*Mode selection input:
Not Used: Keep alive = 0V - waits until battery is low before shutting down and disconnecting.
Keep alive = N.C. - immediate safe shutdown and disconnect.
Raspberry Pi
RPi signals to UPS when it is up. UPS tells Pi to shutdown and waits for RPi_UP to go low before removing power.
RPi_UP=21       # GPIO output - high after boot, goes low a few seconds before complete shutdown. RPi_SD=17       # GPIO input - active-high to trigger shutdown of RPi (through pot.div; 5V >> 3V3).
