Hold fire!
A project log for [mUPS] Minimal UPS for Raspberry Pi
A short hold-up UPS with automatic safe shutdown and reboot
paul-crouchPaul Crouch 04/14/2019 at 13:020 Comments
Dammit! I went to use the Pi and the bloody thing wouldn't power up properly. The power LED lights and the activity LED briefly flickers. A USB meter showed the Pi supply voltage drops to ~3.6V after a short time. Not enough for the Pi to boot.
Maybe I've messed up the wiring and I've got some current going somewhere it shouldn't and something is overheating? I need to pull it apart again to investigate.
