90mm-hexagon-base.stlThe core hexagon component. Print with White PETG. If you go with a less strong material, the snap fit mechanism usually shatters the piece...Standard Tesselated Geometry - 29.96 kB - 03/17/2019 at 18:15 |
faceplate-primary.stlThis is the primary faceplate. Almost every hexagon will have this one.Standard Tesselated Geometry - 12.39 kB - 03/17/2019 at 18:15 |
clear-diffraction-insert.stlThis piece is the insert for the primary faceplate. Print with Clear PETG at 100% infill.Standard Tesselated Geometry - 15.12 kB - 03/17/2019 at 18:15 |
faceplate-solid.stlA solid hexagonal faceplate. I use this to hide the electronic components.Standard Tesselated Geometry - 5.75 kB - 03/17/2019 at 18:15 |
