This code is meant to use a mic to record your voice as if you are a cat in Schrödinger's thought experiment. Sadly, all 292 million possible states are collapsed ounce you claim your prize at your state's capital.
THIS IS ONLY A CHUNK OF THE ENTIRE SCRIPT
Which is only about 18,000 lines long. The code's authenticity is protected by an unconventional cryptographic signature on other sites and is protected by a onetime pad and its trivial to consider xor'n anyway. So don't try too.
import quantumrandom
import os, sys
import gtk.gdk
import time
import pyaudio
import wave
from array import array
A = quantumrandom.randint(1, 70)
B = quantumrandom.randint(1, 70)
C = quantumrandom.randint(1, 70)
D = quantumrandom.randint(1, 70)
E = quantumrandom.randint(1, 70)
F = quantumrandom.randint(1, 27)
time.sleep(10)
if A == A:
D = quantumrandom.randint(10, 70)
FORMAT=pyaudio.paInt16
CHANNELS=2
RATE=44100
CHUNK=1024
RECORD_SECONDS=D
FILE_NAME=D
audio=pyaudio.PyAudio() #instantiate the pyaudio
#recording prerequisites
stream=audio.open(format=FORMAT,channels=CHANNELS,
rate=RATE,
input=True,
frames_per_buffer=CHUNK)
#starting recording
frames=[]
for i in range(0,int(RATE/CHUNK*RECORD_SECONDS)):
data=stream.read(CHUNK)
data_chunk=array('h',data)
vol=max(data_chunk)
if(vol>=0):
print("catisalive-something said")
frames.append(data)
else:
print("\n")
#end of recording
stream.stop_stream()
stream.close()
audio.terminate()
#writing to file
wavfile=wave.open('%s.wav' % FILE_NAME, 'wb')
wavfile.setnchannels(CHANNELS)
wavfile.setsampwidth(audio.get_sample_size(FORMAT))
wavfile.setframerate(RATE)
wavfile.writeframes(b''.join(frames))#append frames recorded to file
wavfile.close()
Tea B
Dylan Brophy
Christoph
Joe Perri
