• Mini Servo Tail
    Paul Gould06/07/2019 at 14:38 0 comments
    2x DS589mg (9Kg.cm 0.1sec/60deg, 40g metal gear)
    1x TGY-306G  (3.7kg.cm, 0.05sec/60deg, 20g, metal gear) best servo ever
    Tail Rotation (left / right)
    Upper Tail Curl (Double Joint)
    Lower Tail Curl (Double Joint)
  • Servo Tail
    Paul Gould06/07/2019 at 14:13 0 comments
    https://www.thingiverse.com/thing:3676891
    3 Servos HK47360TM (23kg/cm, 0.12sec/60deg, "Titanium" Gear, 61g, HV)
  • Wired up, motors calibrated, joints can move
    Paul Gould05/06/2019 at 15:34 3 comments
    Three motors
    Three Controllers
    Three Magnetic Absolute Encoders
    Five Joints
    1Kg
    Motion Control is next
  • Testing
    Paul Gould02/17/2019 at 16:58 0 comments
    It is not moving under its own power yet.
  • ​Range of motion
    Paul Gould02/17/2019 at 16:56 0 comments
    All joints can move ±90°
  • Timing Pulley
    Paul Gould02/17/2019 at 16:46 0 comments
    3mm Pitch timing belt 27 teeth. Dimensions are from a standard timing pulley datasheet.
    1.5mm Hole is for a steel pin to lock the pulley on to the shaft
  • Tail Design - 5 Joints, 3 Actuators
    Paul Gould02/17/2019 at 05:42 0 comments
    By linking two joints a smoother range of motion is possible with less actuators. A figure 8 pulley system using braided fishing line matches the angles of two adjacent joints.
    The next step was to make the tail narrower, which meant placing the motor to the side of the cycloidal gearbox and using a timing pulley to transfer the torque. The joint can now be made 55mm wide.
  • Gear box Design
    Paul Gould02/17/2019 at 05:09 0 comments
    Background
    Autodesk Inventor Parametric Design Cycloidal Gear (from my other project)
    N_  (number of rollers)= 21 ul
    number of teeth = number of rollers - 1
    E_ (eccentricity) = 1 mm
    Rr_ (radius of rollers) = 2 mm
    R_ (radius of Rotor) = 25 mm
    x(t) = (R_*cos(t))-(Rr_*cos(t+atan(sin((1-N_)*t)/((R_/E_*N_)-cos((1-N_)*t)))))-(E_*cos(N_*t))
    y(t) =  (-R_*sin(t))+(Rr_*sin(t+atan(sin((1-N_)*t)/((R_/E_*N_)-cos((1-N_)*t)))))+(E_*sin(N_*t))
    Outer ring design (replaces rollers)
    The + 0.25mm is the tolerance added to on my 3D printer to make it work nicely.
    The whole actuator consists of a brushless motor, motor position sensor, cycloidal gearbox, joint position sensor. All of this is controlled by my custom BLDC controller.
    Cutaway of the Upper Actuator
    This actuator is a similar to the ones used by the legs. It is just a bit smaller. It is only used to "swish" the tail side to side. This type of actuator is 75mm high. This is way too wide to be used for the tail's lower joints.
  • Quadruped Tail
    Paul Gould02/07/2019 at 13:37 0 comments
    Last year I started a new, light 3D printed quadruped using cycloidal gearboxes. It now needs a tail.
    The first design was based around standard RC servos but it was a bit boring. Does there need to be a good reason??? It was a bit slow, lacked torque and had a limited range of motion. Servos were HK47360TM.
    My 3D printer is an very cheap i3 clone. It has an enclosure and a ported extraction system. I print only in cheap ABS, with a raft, on a perforated board. So removing the prints from the bed takes a long time.
    The tail is not finished but it seemed time to share the design in the "3D Printed Gears, Pulleys, and Cams Contest".  The cycloidal gearbox has been proved in the previous project but this time the roll pins has been replaced with 3D printed parts. This reduced the number of parts by half and take ten times less to make. Bearings are still used to handle the torque. Cycloidal gearboxes are great at sharing the torque across multiple "teeth" and "rollers".
