Timing Pulley
A project log for Low Cost 3D printed Robot Tail
Cycloidal gearbox, brushless motors and Timing Pulleys
paul-gouldPaul Gould 02/17/2019 at 16:460 Comments
3mm Pitch timing belt 27 teeth. Dimensions are from a standard timing pulley datasheet.
1.5mm Hole is for a steel pin to lock the pulley on to the shaft
