Stage 1 Hardware, Building A Minimal Z80 Computer
A project log for Building a 22MHz Z80 Computer in 4 Stages
Step-by-step instruction on building a high-performance, CP/M-ready, expandable Z80 computer
plasmodePlasmode 02/10/2019 at 04:470 Comments
In the first stage we'll build a very simple yet functioning Z80 computer with just 4 integrated circuits, plus resistors,  capacitors and hardware.  The bill of materials is included in the Files Section.  In stage 1 the following items will be assembled:
PartNameSource
U1Z84C0020PEGMouser 692-Z84C0020PEG
U2EPM7064SLC44UTSource
U3128Kx8 Static RAMMouser 913-AS6C1008-55PCN
U422MHz oscillator
R154.7K 8-pin SIP BusJameco 1970367
R1-4, R8-9, R16
4.7K, 1/8W
C3-80.1uF bypass
S1Push button SPSTJameco 149948
J12.1mm x 5.5mm Power
Jack
Jameco 101178
T343-pin header
P21x6 right angle female
header
P32x5 header
The pc board artwork is included in the FIles Section, so is the schematic of Z80SBC64 and the Altera EPM7064 programming file.
Here are step-by-step pictorial assembly guides for building a minimal Z80 computer.  The order of assembly is based on the height of the components, the lowest components are soldered down first and the tallest last.  In the first picture, all resistors (4.7K), bypass capacitor (0.1uF), and SIP resistor (4.7K BUS) are soldered down.  Orientation of SIP resistor is important, pin 1 is marked with a black bar and oriented where the red arrow is pointed.
In the second picture, the IC sockets are installed as well as the 1x6 serial port header.
In the third picture, the PLCC socket is installed.  The orientation of the socket is important, the beveled corner should be placed where the red arrow is pointed.  1x3 jumper block (T34), 2x5 programming header (P3), push button (S1), and 2.1mm x 5.5mm power jack (J1) are also installed.
The fourth picture shows the solder side of the pc board.  Because the reset supervisor, U5, is not yet installed, a 4.7K pull up resistor from nRESET to VCC is required to negate the nRESET signal.  Please note, U5 may be optionally installed in this stage.  If U5 is installed, then the pull-up resistor is not required.
The 1st stage assembly is now completed.  The board should be cleaned with isopropyl alcohol and dried before installing components.
In the fifth picture the Altera EPM7064SLC44 is installed.  Observe the orientation of the part, the beveled side with dimple in the middle must be aligned with the red arrow.  Program the EPM7064 with USB Blaster, line up the pin 1 of USB Blaster cable (red strip) with the pin 1 of 2x5 header (pointed by a red arrow).
The last picture shows how the remaining integrated circuits are installed.  Observe the orientation of the components.  Also install the jumper to 'serial bootstrap' position as shown with a red arrow.  Install two jumpers across pin1 & pin8 of U6 and across pin5 & pin6 of U6.  The board is now populated and ready for power.
