Minimalist Li-Ion Charger
Independently charge 10 Li-Ion cells @ 1A each, with $18 of Prime parts and an ATX supply.
To get an accurate capacity reading from scavenged Li-Ion cells, you will likely need to charge/discharge them at least twice.
The charging of the cells proved to be a bottleneck.
This build made that task about 10x faster than my desktop charger, and for less money.
My desktop Li-Ion charger took 4-6 hours to fully charge 2 cells.   2@500mAh
My discharger took a little over 2 hours to fully discharge 4 cells.
After I discovered I needed to cycle each cell again to get an accurate reading, I was waiting on the charging cycle for most of the time.
This build combines some cheap Amazon USB charger modules based on the TP4056 chip which are less than a buck each, some decent (but cheap) Amazon cell holders, some polycarbonate for a housing, and a hacked up ATX supply to do the same task 10x faster.  Here is a link to the parts I used.  Those modules also contain simple output protection for driving a circuit, which I don't use here, but they were the same cost as the ones without it.
I limited the stock ATX supply airflow and drilled a couple well placed holes in my housing.  This let me use the airflow from the ATX supply to cool the cells and charger modules.  The modules still get warm (as they are linear components delivering 1A each), but the cells now stay nice and cool during charging.
The ATX supply itself I got from a metal scrap yard for about $1.50.  I bought three, two worked.  It is running here at <20% rated output and could probably run with zero airflow.  In any case, it stays cool as well.
The charger modules are designed to be directly connected to a cell, and so have no reverse polarity protection.  Plug in a cell backwards, and you'll be buying a new one.  Minimalistic comes with responsibility.  :)  Enjoy.
View all 2 project logs
ActualDragon wrote 4 days ago point
you can also get these: http://www.ebay.com/i/263593791206, and just leave the top off, i made a little 3s li-ion battery out of one, they're awesome little powerbanks
Daren Schwenke wrote 4 days ago point
I was trying to avoid charging the cells in parallel so a bad one can't pull down the entire cycle.  This charges each cell individually for that reason.  Used cells of unknown quality and all.
I've had a couple cells that just sit there turning charge into heat, and never dropping below the cutoff threshold.  The charger has no idea if you have 1 or 20 cells in parallel so it just keeps delivering power.  Some got scary hot in the process, hence the active cooling now.  I'm doubling the heating now if I put a bad cell in, but at least it will fail all by itself.
That being said, your solution would make a good charger for lots of 'good' cells.  :)
Mike Szczys wrote 5 days ago point
Geez, you're getting a million great projects out of these cells. I loved the capacity tester ( #Minimalist Li-Ion Discharger/Capacity meter. ) and of course the spot welder ( #Minimalist Li-Ion Cell Welder ) is delicious -- can't believe it's that simple.
Great job all around.
Once you get that mountain board battery pulled together, how long do you think it will last? I longevity of salvaged cells just a matter of wise maintenance?
Daren Schwenke wrote 5 days ago point
That is the one area I have thus far spent money, to save money. It has a proper BMS just because my son will be the one managing it, and I imagine running it completely dead would happen on the first run otherwise.  It was like $20 on Amazon.  I don't know how long the cells will last as they are all used, but I am within the proper rate of discharge with my 5p pack, so it should be a decent amount of time.  I'll be happy if I get a year out of them.  Given I probably saved $300 on the battery alone, I'll take what I can get.  I can always build another one now.  :)
