20221211_124747.jpgTray with JLCPCB manufactured tray power distribution board, along with my original prototype tray power distribution boardJPEG Image - 2.39 MB - 12/11/2022 at 17:52 |
20221211_124757.jpgMain power distribution boardJPEG Image - 2.43 MB - 12/11/2022 at 17:51 |
20190422_224423.jpgComponent side of the charging tray power distribution board up closeJPEG Image - 173.58 kB - 04/23/2019 at 02:51 |
20190422_224411.jpgSolder side of the charging tray power distribution board up closeJPEG Image - 215.32 kB - 04/23/2019 at 02:51 |
20190422_224355.jpgCharging tray power distribution boardsJPEG Image - 227.06 kB - 04/23/2019 at 02:51 |
ChargingTrayPwrDist.jpgI will be using this board in place of the mangled mess that I soldered up for the power distribution on the first try.JPEG Image - 64.40 kB - 04/14/2019 at 17:08 |
20190406_234433.jpgSingle tray example with all battery cells filledJPEG Image - 261.44 kB - 04/07/2019 at 03:48 |
20190406_234446.jpgSingle tray example with one battery not installedJPEG Image - 254.45 kB - 04/07/2019 at 03:48 |
20190406_234426.jpgSingle tray up and running, still need to dress the whole project upJPEG Image - 276.78 kB - 04/07/2019 at 03:48 |
20190326_204325.jpgJust a close up of the female spade terminals that fuses will be installed into, but since I had some overlap of the heat shrink tubing covering the opening, I had to trim some of it.JPEG Image - 240.58 kB - 03/30/2019 at 16:48 |
20190326_201733.jpgJust another angle of the completed power adapter board prepped to add heat shrink to the female spade terminalsJPEG Image - 333.08 kB - 03/30/2019 at 16:48 |
20190326_201716.jpgThe completed power adapter board prepped to add heat shrink to the female spade terminalsJPEG Image - 318.50 kB - 03/30/2019 at 16:48 |
20190326_204013.jpgFocused on the 20 female spade terminals that will be used to connect an on/off switch to the power adapter board, to show the heat shrink I put on the spade terminalsJPEG Image - 227.00 kB - 03/30/2019 at 16:48 |
20190326_204003.jpgFocused on the 2 female spade terminals that will be used to connect an on/off switch to the power adapter board, to show the heat shrink I put on the spade terminalsJPEG Image - 182.62 kB - 03/30/2019 at 16:48 |
20190326_195251.jpgAnother photo of the fasteners and spacers as better described belowJPEG Image - 234.96 kB - 03/30/2019 at 16:47 |
20190326_195245.jpgI was and still intend to use spacers and these automotive body fasteners (christmas tree fasteners), to hold the ATX power adapter to mount the power board to a shelf but these fasteners are too wide for the holes I had designed/made for this board.JPEG Image - 238.74 kB - 03/30/2019 at 16:47 |
20190326_195025.jpgMy ATX power adapter board with all the parts soldered onto that I want to useJPEG Image - 234.51 kB - 03/30/2019 at 16:47 |
20190324_162043.jpgTest fitting of charging trays 1JPEG Image - 211.01 kB - 03/24/2019 at 20:33 |
20190324_162038.jpgTest fitting of charging trays 2JPEG Image - 252.47 kB - 03/24/2019 at 20:33 |
20190324_161823.jpgTest fitting of charging trays 3JPEG Image - 222.52 kB - 03/24/2019 at 20:33 |
20190324_161719.jpgTest fitting of charging trays 4JPEG Image - 224.85 kB - 03/24/2019 at 20:33 |
20190324_161729.jpgTest fitting of charging trays 5JPEG Image - 223.61 kB - 03/24/2019 at 20:33 |
20190324_161806.jpgTest fitting of charging trays 6JPEG Image - 242.82 kB - 03/24/2019 at 20:33 |
20190324_161711.jpgTest fitting of charging trays 7JPEG Image - 233.49 kB - 03/24/2019 at 20:33 |
20190324_161804.jpgTest fitting of charging trays 8JPEG Image - 233.04 kB - 03/24/2019 at 20:33 |
20190320_220145.jpgATX Adapter Pic 1JPEG Image - 317.60 kB - 03/21/2019 at 02:10 |
20190320_220154.jpgATX Adapter Pic 2JPEG Image - 316.66 kB - 03/21/2019 at 02:10 |
20190320_220211.jpgATX Adapter Pic 3JPEG Image - 203.96 kB - 03/21/2019 at 02:10 |
20190320_220204.jpgATX Adapter Pic 4JPEG Image - 199.16 kB - 03/21/2019 at 02:10 |
Gerber_ATX 24 Pin Vertical Layout_20190320215318.zipGerber file containing the layout for the SparkFun 24 Pin ATX vertical connector part number: PRT-09497x-zip-compressed - 3.74 kB - 03/21/2019 at 02:03 |
20190317_153804.jpgTop view of the power distribution board showing the female spade connectors with the fuses installedJPEG Image - 213.02 kB - 03/17/2019 at 20:04 |
20190317_153809.jpgTop view (60/30) of the power distribution board showing the female spade connectors with the fuses installedJPEG Image - 186.14 kB - 03/17/2019 at 20:04 |
20190317_153654.jpgTop view (60/30) of the power distribution board showing the female spade connectorsJPEG Image - 219.39 kB - 03/17/2019 at 20:04 |
20190317_153648.jpgTop view of the power distribution board showing the female spade connectorsJPEG Image - 235.90 kB - 03/17/2019 at 20:04 |
20190317_151316.jpgJust a picture of the positive wires soldered to the power distribution board on the charging trayJPEG Image - 302.14 kB - 03/17/2019 at 19:54 |
20190317_145050.jpgJust a picture of the negative wires soldered to the power distribution board on the charging trayJPEG Image - 308.11 kB - 03/17/2019 at 19:53 |
