redoing last experiment
A project log for enhancement to depletion
DIY method to lower gate threshold voltage of regular MOSFETs, ultimately reversing it.
deepsoicDeepSOIC 10/28/2016 at 20:501 Comment
In progress now. So far, it is going rather similarly to a previous one, even though that previous one was done on defunct circuit.
The threshold voltage is now rising again.
UPDATE: finished.
Unprocessed data available in files: TORTURE2.TXT. Note: torture currents are chopped with 50% duty cycle, so the average currents into gate are half the indicated values.
Kinda similar to what I got with broken circuit. Except, this time:
* fresh transistor
* final current was 1 uA, not 0.3 uA
* I almost reached the end of the process =)
Yann Guidon / YGDES wrote 10/29/2016 at 11:26 point
Wow... A single MOSFET could create a very very slow time constant... of course, temperature dependent :-D
