Dotstars, are fragile.
A project log for Christine's Blooming Rose
3D printed, heat formed, servo actuated blooming, Dotstar module lit, rose.
daren-schwenkeDaren Schwenke 03/02/2019 at 04:220 Comments
Unseated, and wired up the Dotstars I was using to light the stem leaves with magnet wire.
Colored the magnet wire for my own sanity with a sharpie.  Mostly worked.
Fed the wires into the stem, so far so good..
Ran the touch sense wire from the leaf, and pressed the modules in, and broke one.
I guess 0.4mm was not enough tolerance for the slot they go into in the stem.  BAH.
Remodeled.  Reprinting.
<EDIT>
And now.. remember to close the printer door after taking your picture, so the part doesn't lift off the bed. I modeled in a 'brim' only on the ends to make cleanup more tolerable, but a consistent temperature is a requirement.
Reprinting.
</EDIT>
