Zero walls is a thing..
A project log for Christine's Blooming Rose
3D printed, heat formed, servo actuated blooming, Dotstar module lit, rose.
daren-schwenkeDaren Schwenke 03/16/2019 at 10:070 Comments
Experimented in Cura to find the best settings for printing the petals.  The result which worked the best by far, was a bit strange.  I set Cura to only print infill, and it worked flawlessly.
No travels at all minus moving from the center of each petal to the center hub.  It's basically printed as much as is possible, as a single extrusion.  The results are fantastic.
