OHSC Hybrid stepper motor controller
OHSC is an open source hybrid stepper motor controller and force feedback interface using FOC to apply smooth torque on a budget.
Public Chat
The goal of this project is to develop a simple and comparably cheap interface for stepper motors as an alternative to expensive industrial servo motors.
Hybrid steppers bridge the gap between servo motors and open loop stepper motors.
Traditional stepper motors must be driven with high current without position feedback to avoid skipping steps and can not be driven in stall conditions to apply smooth torque like servo motors can.
In this project an open source hybrid stepper driver with traditional step/dir and serial interfaces is developed and an alternative force feedback firmware for simracers with standard HID gamepad interface.
The options of current hybrid stepper drivers are very limited and dated let alone open source.
Some use cases allow for a bit less precision and smoothness than a perfect servo for thousands of dollars could deliver and are out of reach for most hobbyists and diy projects.
This is where steppers come into play when paired with a sub microstep precision encoder and a smart foc based controller constantly monitoring the position and applying torque in the desired direction with a set power and electrical target angle.
By using a standard powerstep01 stepper driver a robust driver with precise power regulation is available without having to manage this in the main controller.
It can supply power up to 10A 80V and can be managed via spi and setting the electrical FOC angle is done by sending bursts of steps to correct the position via the stepclock interface.
It will be controlled by an stm32 which is also capable of usb HID communication and that opens the possibility for the main inspiration for this project: Force Feedback.
Another interesting use case comes from the simracing community.
Force feedback racing enthusiasts often use industrial stepper motors with expensive controllers as direct drive wheels. While i researched the available options there were none that really satisfied my idea of a diy ffb wheel as most options were very expensive servo drives or commercial products with a premium price tag.
Stepper motors are much cheaper for comparable torques and make a hybrid stepper perfect for direct drive wheels.
  • 1 × Powerstep01 Power Management ICs / Motion, Motor and Servo Control
  • 1 × STM32F411RCT6 or STM32F103RCT6 Main Processor
  • 2 × DTSM-6 Switches and Relays / Switches
  • 1 × USB_MICRO-B Connector
  • 2 × 68µF Caps 100V
View all 20 components
  • Choice of processor and control
    Yannick (Gigawipf)04/17/2019 at 13:17 0 comments
    Of course we need some way to send data and control signals to the OHSC for setup and direct control of important parameters.
    A good option would be a serial port. This would make it usable in programs and in a terminal for human users.
    It already has a hardware uart interface planned that could always be used to control everything important. But this needs a uart interface so in normal operation it would be nice to just use one usb port.
    As it is planned that the device can also be used as a HID gamepad for FFB we need some way to control it when HID is active. One option would be to use a hardware uart for that or HID feature reports that would make it impossible for a human user to control without a pc application.
    The best option would be to have hardware uart pins open and in hid mode setup a composite usb device with HID and CDC com port at the same time and if you don' need HID it just enables the CDC part.
    This is pretty hard to do with STs HAL libraries but should be the most compatible and usable option.
    So this is what i tried to setup and kind of succeeded until i found the reason why it would never transmit via CDC or break the HID part depending on the used endpoints.
    It turns out that the F4 only has 4 usb endpoints and HID needs two, CDC needs two or 3 with CMD and then there is EP0... So i need at least 5 endpoints.
    I could have spotted this by reading the datasheet more carefully which advertises "4 bidirectional usb endpoints". I thought that meant 4 IN and 4 OUT each but that is not the case.
    Therefore it is not possible to setup a bidirectional composite device with an stm32F4.
    The F1 line actually does allow more endpoints and only the faster F4 and F2 lines have this 4 EP limitation.
    Now there are some options for the next iteration:
    • Stay with F4 and either send controls via HID features as initially planned/switch between CDC and HID
    • Hardware uart interface and have 2 usb ports and F4
    • STM32F103RC without HW float (not really needed but nice to have)
    • STM32F7 (much more expensive, way faster and generally overkill)
    At the moment i would probably try the slower and cheaper F1 to stay in budget and keep the board small as there are some more modifications needed for the next iteration like braking resistors and anti backfeed.
    The pinouts are compatible and only the usb resistors would have to be changed to switch to an F7 or stay with the F4. Everything else is software configuration.
    The F1 would cost around 4€ in single quantities and very easy to get, the F4 almost the same with 5€ and the F7 would be almost 10€ and make the device more expensive.
    The F411 has a usable clock speed of 96MHz and the F1 only 72MHz but that is still more than enough. The F7 clocks at over 200MHz and is pretty overkill for the rather slow usage as most of the time is already spent waiting on spi and usb and the encoder is managed by a HW timer.
  • First PCB tested
    Yannick (Gigawipf)03/28/2019 at 19:32 3 comments
    Finally the first pcb arrived and is tested to find any errors in the design and see if there are any major issues.
    Soldering everything by hand takes some patience but everything works as it should.
    A few problems spotted in the first design:
    1. Vias under the current shunts are too close to the pads and can be bridged to the resistor while soldering and short out the shunt voltage.
    2. Pullups of encoder were connected to 5v instead of 3.3v. Easy to bodge for now and fixed in the next version.
    3. 3.5mm terminals might be too small for big motor wires. Maybe add a 5mm footprint and move the caps and buttons.
    4. USB footprint from eagle not exactly the correct one for the ports. Drilled holes are in slightly different spots.
    Strange as the part numbers were identical and can be fixed by bending the mounting pins of the port inwards but should be changed to the correct one.
    Apart from that the driver and processor work correctly. I chose the STM32F411 as the main processor running at 96MHz. 2 LEDs for status messages, one power led and one direct driver flag led for critical errors are present on the board.
    And of course the gamepad communication is working with 16 buttons and 8 analog inputs.
    The encoder input is correctly scaled to 1080° of rotation and perfectly matches the virtual wheel in project cars.
  • Designing a pcb prototype
    Yannick (Gigawipf)03/05/2019 at 16:28 0 comments
    While the current prototype shows promising results it is a mess of wires and many pins on the stm are already blocked by the discovery board. Other boards where the powerstep shield can be stacked onto often have no usb port or other issues.
    I spent quite a few days researching parts, designing a pcb and preparing the cubemx project for the new layout and chip.
    For the next prototype i chose the stm32f411RCT6. This processor has enough pins for 8 analog and 16 digital pins directly connected to the chip while still having usb, uart, internal spi for the powerstep and screw terminals for the encoder.
    Some space is available to allow for a larger heatsink if needed. In theory it should be able to handle 80V but in current mode the driver runs best at 12-20V and this is probably what most users will have available anyways. At higher voltages the driver get really hot. In voltage mode not that much but i find the torque reaction to be much smoother and quicker in current mode.
    Now i will wait for all the parts to arrive and hope that nothing blows up in the first test.
    One other thing still missing is a nice nema34 dual shaft motor. The 34HS59-5004D from stepperonline looks like a perfect match with pre cut keyway and smaller back shaft and mounting holes for the encoder. Sadly it is not available at the moment so i will need to wait more or find a different one.
    After a week my parts finally showed up except for the terminal blocks.
    Not the most pretty soldering but it was all hand soldered and that lqfp powerstep is a beast to hand solder. Cleanup will be done once the terminal blocks are here.
  • Prototyping and FOC
    Yannick (Gigawipf)02/15/2019 at 19:47 0 comments
    My prototype consists of a stm32f4 discovery board and a powerstep01 shield.
    The goal of this stage is to implement a stable FOC control loop using this standard stepper driver. I chose this driver because it allows for up to 10A of current in current and sine voltage mode and can be controlled via spi quickly and stepped in stepclock mode.
    The field oriented control like approach works by keeping track of the step positions and aligning bursts of microsteps less than one electrical rotation to the current position and making sure the stepper never skips a full step.
    This needs a high resolution encoder with sub microstep resolution. I chose a 10k count E6B2CWZ6C (clone) encoder for this prototype.
    Microstepping is set to 1/16 because this is the highest setting the driver supports in both current and voltage mode and current mode allows for higher holding power between steps.
    Perfect alignment of the shafts is crucial for smooth stepping so a sturdy adapter was printed.
    Yes it is messy but there is no other option to get the driver connected to this board. The end result will feature a custom pcb :)
    The FOC loop is pretty much working right now and can turn heavy loads at stall conditions without cogging and the feeling of skipped steps.
    This video was made with <0.4A of current and a Nema 24 motor. Imagine a Nema 36 or 42 at up to 10A.
    The feeling is smooth as butter when forcing the load away. Very unlike an open loop stepper.
    At the moment the position holding is done using a PID loop which has to be tuned for the specific load and torque profile needed. This creates some overshoot which has to be reduced for accurate applications. Of course in this video the overshoot is extremely exaggerated because of the heavy load but even with small loads about 1-5 microsteps of overshoot and offset can be observed when the loop is reasonably tuned but not perfect.
    Later a step/dir interface to use this closed loop controller as a replacement for open loop stepper drivers will be implemented and this will need at least near microstep accuracy to be usable but the main goal is to provide smooth torque at stalls for applications that would traditionally need servo motors like linear actuators, force feedback and robots.
View all 4 project logs
Daren Schwenke wrote 05/11/2019 at 19:35 point
I have always dreamed of a controller board which could handle both steppers and BLDC motors.  FOC applies to both in the realm of what you have done here.  The H-bridges required don't care if they are all bound to a single motor, so the same board could effectively handle both 3 stepper motors (6 H-bridges required), or 2 BLDC (3 phase delta wired) motors (6 H-bridges required) and use FOC control.  Just a thought...  :)
