HASP v0.38 release
A project log for HASwitchPlate
An LCD touchscreen you can mount into a standard North American work box in place of a light switch for Home Automation control
lumaluma 06/27/2019 at 12:240 Comments
HASP v0.38 release
Stability and performance improvements
ESP8266 code v0.38
Home Assistant Automations
ESP8266 Update Procedure
If you’re using the AutoFirmwareUpdate automation your devices should pull this update at 3:00am. Otherwise, log into the admin web page and you can pull the update from the firmware page.
Home Assistant Update Procedure
Run the deployhasp.sh script to pull down the updated automations using one of the guides below:
Links for more HASP info
