Having to borrow a car with a metal roof to test the system is a pain. The antenna spacing for VHF is about 18". My cars have sunroofs - metal tops with big glass holes. There is no way to attach the four magnet mount monopoles with the required spacing because of the sunroof location. I can magnetically mount to the roof with a trestle over the sunroof but that is a problem for the monopoles - no uniform ground plane. That can be solved by going with a dipole array. The height of the array would be about 36" plus the trestle height. Rubber duckie's for the elements might be a tradeoff.
A dipole array can be a single unit so a positioning sensor can be built into it. The system is needs be calibrated once and shouldn't need recalibration between installations and removals.
Here's a stationary array - just four antennas should be sufficient:
