Syringe Driver.schEagle schematic of the electronic components. This was one of my first Eagle files and one of my first component layouts, so it may not be the best.sch - 179.18 kB - 02/18/2019 at 17:42 |
Syringe Driver Cork Rev1.STLMain drive spiral. I forget which orientation I used to print this part. I want to say horizontal orientation worked really well with minimal supports needed.Standard Tesselated Geometry - 724.98 kB - 02/18/2019 at 17:42 |
Standard Tesselated Geometry - 36.02 kB - 02/18/2019 at 17:42 |
Syringe Driver 1 Rev1.STLMain body which press-fits the syringe, has mounting holes for the motor, and accepts a top and bottom cover to hold everything inside.Standard Tesselated Geometry - 70.79 kB - 02/18/2019 at 17:42 |
Standard Tesselated Geometry - 51.84 kB - 02/18/2019 at 17:42 |
Syringe Driver Top Rev1.STLKeeps the syringe plunger arm from skipping over the top of the corkscrew.Standard Tesselated Geometry - 8.09 kB - 02/18/2019 at 17:42 |
Syringe Driver Bottom Rev1.STLKeeps the corkscrew from bending too much during use.Standard Tesselated Geometry - 10.24 kB - 02/18/2019 at 17:42 |
