Main flashing cycle contains 5 TIM4 tick. During TIM4 ticking, orderstate variable moves from 0 to 4 and returns to 0.
orderstate
0 1 2 3 4
|250мс|250мс|250мс|250мс|250мс|
switch (flow_state) // looking for flow state
case 1: // switch FLOW ON
if (PB_ODR_bit.ODR2 == 0) PB_ODR_bit.ODR2 = 1;
case 0:// switch FLOW OFF
if (PB_ODR_bit.ODR2 == 1) PB_ODR_bit.ODR2 = 0;
switch (oiler_status) // looking for global status and fire led
case _idle:
PB_ODR_bit.ODR7 = idle[orderstate][0];
PB_ODR_bit.ODR6 = idle[orderstate][1];
break;
case _someoil:
PB_ODR_bit.ODR7 = someoil[orderstate][0];
PB_ODR_bit.ODR6 = someoil[orderstate][1];
break;
case _littleoil:
PB_ODR_bit.ODR7 = littleoil[orderstate][0];
PB_ODR_bit.ODR6 = littleoil[orderstate][1];
break;
case _nocurr:
PB_ODR_bit.ODR7 = nocurr[orderstate][0];
PB_ODR_bit.ODR6 = nocurr[orderstate][1];
break;
case _overcurr:
PB_ODR_bit.ODR7 = overcurr[orderstate][0];
PB_ODR_bit.ODR6 = overcurr[orderstate][1];
break;
case _flow:
break;
if (orderstate >= 4) {orderstate = 0;} else {++orderstate;};
TIM4_SR1_bit.UIF = 0;
