PCB Update
A project log for Ariel Flight Control System
A system designed to actively control a rocket's altitude precisely and accurately. For use in Team America Rocketry Challenge.
michael-cuthbertsonMichael Cuthbertson 06/21/2019 at 13:310 Comments
Basically I forgot I even had an account here until I got an email. The PCB has been redesigned about 25 times. Finally got a one sided design I'm happy with. The PCB has been milled and drilled, all of the components soldered. Everything works as intended. There will eventually be a video on the milling and drilling of the PCB, but may be a week or two.
