HACKDAY_FINAL.PCB
PCB file, for Protel Client PCB editor
pcb - 502.74 kB - 12/07/2016 at 13:21
Download
HACKADAY_P3.zip
Gerbers for PCBs. Five badges on a single panel.
x-zip-compressed - 178.03 kB - 12/07/2016 at 13:17
Download
ChallengeB.HEX
The same challenge firmware, modified for the first version of the badge, used at Belgrade conferrence, April 9th 2016.
hex - 16.20 kB - 12/06/2016 at 20:53
Download
Challenge.HEX
Solve the puzzle and win a prize!
Good luck!
hex - 16.56 kB - 11/05/2016 at 17:10
Download
Badge Manual V1R0.pdf
Same manual, if you prefere PDF format
Adobe Portable Document Format - 1.39 MB - 11/05/2016 at 04:35
Preview
Download
Badge Manual V1R0.docx
A brief manual for badge hacking
document - 1.78 MB - 11/05/2016 at 04:27
Download
demo 2.HEX
File ready to be bootloaded by Hackaday Superconference Badge. It is very similar to the file DEMO 2.HEX from the .ZIP file, only a few timing constants were modified.
- 19.35 kB - 11/05/2016 at 18:57
Download
kernel 2.hex
Firmware for Hackaday Superconference Badge, ready for MCU programming. Contains Bootloader (0x0000 - 0x2AFF) and Kernel (0x2B00 - 0x32FF). This file is the same as in the .ZIP file, available here for convenience.
hex - 35.46 kB - 11/03/2016 at 04:12
Download
Kernel 2.zip
Source files for Superconf II badge.
Kernel 2.asm also contains bootloader 2.inc, which is actually the bootloader binary file, organized as data table.
Demo 2.hex should be bootloaded via USB.
Everything (except the bootloader) is written in assembly language.
Detailed description will be available soon.
x-zip-compressed - 368.33 kB - 10/22/2016 at 20:17
Download
