Testing the Functions When Put Together
A project log for Work Table Light
The goal is to learn about ADC as well create a custom and unique work table light.
Alvi AhmedAlvi Ahmed 02/23/2019 at 08:240 Comments
In this log, I put the functions all together in one file and see if they can work together without any bugs or complications.
After these tests, I seems that the only bugs are flickering and the nightmode not properly working. This can due to a number issues from hardware to software.
Further tweaking of the code will be necessary in order to mitigate the flickering.
The next step will be to create the full the schematic, design the actual table light and where each strip should go. As well fixing the code.
