Stage 2, A minimal 68030 computer
A project log for Building a 68030 computer in 5 stages
Based on Tiny030 design
PlasmodePlasmode 02/21/2019 at 16:150 Comments
Once the CPLD is checked out and working, we are ready for stage 2.  Stage 2 is to assemble a bare minimum 68030 computer that contains 68030, RAM, CPLD and an oscillator.
There are a number of manual wires need to be done at the back of the board:
A prototype board with additional manual wires need to plug into the expansion headers, U11 to enable the serial bootstrap function
Here is the board that's ready to power up.
The USB-to-serial adapter connects to terminal emulation (I use TeraTerm) program at 115200-N-8-1.  Programmed in the CPLD is a simple serial port and DMA circuitry controlled by a state machine.  At power up the CPLD state machine generates a bus request to 68030, then the state machine takes control of the 68030 address and data bus and waits for serial data input.  Every data received is DMA to memory starting from location 0x0 until 255 bytes of data is received.  At that point the state machine relinquishes the bus and 68030 starts program execution from 0x0 like a normal power-on reset operation.  The small 255-byte program is typically a simple file loader that load more sophisticated application programs.  This is the mechanism by which the minimal 68030 computer can be loaded with diagnostic software to further test the board and to develop application software.
A reasonable question can be ask whether this stage is consider a "baby step" due to the many manual wires where mistakes can easily be made.  That's a good point for this particular version of pc board, but I also want to use this experience to develop a revised pc board where stage 2 can be done without too much manual wiring.
This is the CPLD file for stage 2 68030 computer
