Stage 2, Running Software on the minimal 68030 computer
A project log for Building a 68030 computer in 5 stages
Based on Tiny030 design
plasmodePlasmode 02/25/2019 at 01:500 Comments
The minimal 68030 computer has 512K of RAM and a simple serial port.  Here is the memory map of stage 2 68030 computer:
A very simple program to output 'hello world' on console looks like this:
    org 0
    dc.l $80000        ;define stack
    dc.l start
start:
    lea signon,a0        ;point to sign on message
chktxempty:
    btst.b #0,$FFFFF001    ;test for transmit buffer empty
    beq chktxempty
    move.b (a0)+,$FFFFF000    ;write next character to console
    bne chktxempty            ;until null terminator
    bra *                    ;spin forever here
signon: dc.b $a,$d,'Hello World!!!!!',0
    end
The assembler for this code is EASy68K.  The EASy68K tool chain has an utility, EASyBIN, that can convert S-record to binary format and fills the file to specified length which is 0xFF in this case.   This way the program will start running as soon as file loading is completed.
OK, now that 68030 can receive a 255-byte program and execute it, let us write a 255-byte S-record loader.  This simple loader will load a S-record file and start program execution from 0x400 when loading is done.   To test this loader, I modified the above 'hello world' program so it starts from 0x400.  First load the S-record loader, and then load helloworld_400.
That works, so I will now load and execute a memory diagnostic that checks the 1/2 meg RAM from 0x1000 to 0x7FFFF.  The program and stack reside below 0x1000 so that part of the memory can't be checked with the diagnostic.  First load the S-record loader, then load tstmem.s68
That works well, now I'm ready to load a real application, Lee Davison's EhBASIC for 68000.  This program is available for download from EASy68K website.  The source code is modified slightly to accommodate the simple serial port.  Once EhBASIC is loaded and running, I will load a ASCII mandelbrot program and run it under EhBASIC.
This collection of software demonstrate the stage 2 hardware is working properly and we are ready to move on to stage 3.
