Automatic calling - Twilio
A project log for Design and Build a Companion Robot for MS Care
The project aims to design and build a companion robot for aid in primary and secondary progressive Multiple Sclerosis care.
joshastley1joshastley1 03/27/2019 at 14:420 Comments
The automatic calling function is facilitated by an online service called Twilio. Multiple similar services are available and most provide tutorials on how to make outbound calls. for this project I use only outbound calls so a trial account is sufficient however if you wish to receive calls and send multiple calls then a full account is required. The companion robot can be customised to say whatever is desired and is something that can be developed in-conjunction with patients needs.
