Sensor Circuitry - Making it smaller
A project log for Gesture Controlled Smartwatch
A larger, more functional smartwatch with gesture controllability
Thomas McKinneyThomas McKinney 03/14/2019 at 20:540 Comments
I did originally plan on using stripboard for the final wiring of the sensors, however I think my electrics knowledge just isn't good enough... I designed the layout and attempted several times at the soldering of it - but no luck:
Have I messed up with this design???
Where the purple represents the sensor connection points. The green represents the resistors going to ground. And the red represents the power pathway and the wire connections back to analog.
