Components
A project log for Gesture Controlled Smartwatch
A larger, more functional smartwatch with gesture controllability
thomas-mckinneyThomas McKinney 03/04/2019 at 16:100 Comments
So I followed the steps in the adafruit gameboy build instructions:
https://learn.adafruit.com/pigrrl-2/overview
^ This is a brilliant way to bypass the need for using GPIO pins for an audio output.
Is there another way to do this??
Brought these components:
Power Slide Switch [ADA805] - https://thepihut.com/products/adafruit-breadboard-friendly-spdt-slide-switch
PowerBoost 1000 Charger Board [ADA2465] - https://thepihut.com/products/adafruit-powerboost-1000-charger-rechargeable-5v-lipo-usb-boost-1a-1000c
Silicone Wire [ADA1877] - https://thepihut.com/products/adafruit-silicone-cover-stranded-core-wire-2m-26awg-red
Audio Board [ADA2130] - https://thepihut.com/products/adafruit-mono-2-5w-class-d-audio-amplifier-pam8302
Miniature Speaker [117-6046] - https://uk.rs-online.com/web/p/miniature-speakers/1176046/
Lipo Battery (2000mAh) [BAT0005] https://shop.pimoroni.com/products/lipo-battery-pack?variant=20429082247
Now its time to start building...
