Smartwatch Speaker in Action
A project log for Gesture Controlled Smartwatch
A larger, more functional smartwatch with gesture controllability
thomas-mckinneyThomas McKinney 03/04/2019 at 16:360 Comments
Following on finishing all of the soldering from my last entry, here's a little video of it up and running:
There was no coding needed to get this working after the soldering.
Its very quiet, but that is because the speaker requires a backing board behind it in order to get its full potential. When it comes to designing the case for this watch, I will engineering this backing board into it. So on the final product the speakers work to full affect.
