NPR New Packet Radio
IP over 430MHz Ham Radio, up to 500kbps, 20W RF.
Extension for HSMM-Hamnet-AREDN. 100% open-source.
Public Chat
NPR (New Packet Radio) is a custom radio protocol, designed to transport bidirectional IP trafic over 430MHz radio links (ham radio). This protocol is optimized for "point to multipoint" topology, with the help of managed-TDMA.
Bitrate is up to 500kbps (net, effective bitrate).
The radio modem is cheap (~80$) and home-made, with a 433MHz ISM module inside. The modem is connected locally with Ethernet, therefore no specific software is needed on PC.
The modem is easy to build and reproduce.
You can add a DMR radio amplifier in order to achieve 20W radio power or more.
The main usage is an extension of HSMM - Hamnet - AREDN networks.
All the project is open-source : hardware, software, protocol specification.
If you have questions, you can use the public chat room, or contact me via e-mail : f4hdk[at]free[dot]fr
watch full screen.
Documentation and PCB design
Introduction and
quick start guide
English
Introduction
et guide de
démarrage rapide
Français
Advanced user guide (EN & FR)
Modem assembly and programing guide (EN & FR)
PCB design files and Gerber
NPR protocol Specification (EN)
Modem Firmware : binaries and sources
Last version (stable)
2019_04_06
Binary file
Release note
Source code
Adobe Portable Document Format - 1.63 MB - 04/08/2019 at 18:57
Preview
Download
text/plain - 1.58 kB - 04/07/2019 at 17:42
Download
octet-stream - 144.98 kB - 04/07/2019 at 17:31
Download
plain - 1.18 kB - 04/07/2019 at 17:30
Download
x-zip-compressed - 5.07 MB - 04/07/2019 at 17:27
Download
View all 13 files
View all 4 project logs
IZ7BOJ wrote 04/13/2019 at 12:22 point
Hi Guillaume, I’m following NPR since the beginning, but I didn’t find any useful detailed study about that before your nice article.
I practiced packet radio for many years, I’ve built several S53MV wide-band radios, experimented TCP-IP over ax25 and I regret that period!
Now I’m very excited about NPR. I’m trying to involve other local OMs in order to build a small experimental network.
Thinking in a “daydreaming way”, IMO one limitation in the protocol could be the maximum number of clients (7).
What appens to the 8th client which send a connection request? Just receive a reject like the AX25 “BUSY”? Then the user should periodically retry until one of the clients disconnects from the master?
Best 73’s
Alfredo IZ7BOJ
f4hdk wrote 04/14/2019 at 06:54 point
Thanks a lot Alfredo for your feedback.
Answer to your question : if a 8th client tries to connect, then it receives a "NACK" (reject from the Master), and the client modem tries periodically (every 15 sec) to send new connection request, and therefore it will automatically connect as soon as a "client slot" is free.
Initially, my idea was that each client should use its connection for a short period of time (several dozens of minutes) each day. It is currently not designed for 24H/24 connection.
But if there are lots of demand, I will think about increasing this limit to 16 or 32 clients. I will need to make software modification at Master side only.
stevewilliam007 wrote 04/12/2019 at 07:36 point
I have been searching for the packet radio and recently heard from https://elgforum.com/ about the newly releasing packet radio which has helped me a lt. There are several latest technologies which are trending in the market.
f1rzn wrote 04/05/2019 at 08:32 point
Ca fait des années que j'espère quelquechose dans ce style, qui nous redonne les mêmes possibilités que le packet radio mais en version moderne. Je me suis permis de partager sur le groupe AREDN (le successeur de BBHN) et sur 2 ou 3 autres pages. Ca me parait très complémentaire de l'AREDN. Franchement bravo et merci. J'espère qu'un jour on aura un satellite geostationnaire qui viendra compléter les possibilités terrestres que cela offre. Ca manque un réseau mondial de données radioamateur.
f4hdk wrote 04/05/2019 at 12:27 point
Merci beaucoup pour ton retour. Préviens-moi si tu veux tester cette solution. Tu as mon e-mail si besoin : f4hdk[at]free[dot]fr
F4HZO wrote 04/03/2019 at 20:06 point
Super ce système cela offre des possibilités inédites en matière de couverture Hamnet surtout pour les communications d'urgences !
Merci de partager la connaissance !!
Meilleurs 73 de Florent F4HZO
f4hdk wrote 04/04/2019 at 17:17 point
Merci!
bferrell wrote 04/03/2019 at 19:58 point
In regards the 433Mhz ISM module, Adafruit has one for just a bit under $10 US
DL4APT wrote 04/03/2019 at 12:06 point
if i find the time i will look into modifying the design to use this much cheaper Ethernet module (same chipset but less then 4€ compared to the 20€) https://de.aliexpress.com/item/Free-Shipping-Q00216-1-Piece-USR-ES1-W5500-Chip-New-SPI-to-LAN-Ethernet-Converter-TCP/32435030006.html
Jackson wrote 04/03/2019 at 03:56 point
The DMR radio amplifier is available here: https://www.radioddity.com/collections/mobile-radio-amplifier/products/vgc-vr-p25ud
Up to 40W output, really powerful
Richard Green wrote 04/02/2019 at 21:45 point
I'd like to experiment with this in the USA.  I can't seem to find a source for several of the critical parts.  Farnell has a subsidiary nearby, called Newark Element14, and all the small parts are available there.  The PCB I can get manufactured locally.  But two of the modules seem to be unavailable.  The itead LM2596 voltage regulator module is listed as 'Retired' on their website, and I have not found any source for the RF4463 F30 module at all.  aliexpress carries a 'demo board' carrier for it and similar, but not the modules themselves.
If I can find sources for the parts, I'd consider doing a mass order, and making up kits to sell at the big Hamvention next month.
I do have one concern about the protocol itself.  For the most part, NPR concerns itself only with the Physical and link layers, but why does it also act as a DHCP server?  Why not keep it pure and leave that to the IPv4 router?  And allow other protocols (ICMP, IPv6) as well?
f4hdk wrote 04/03/2019 at 03:23 point
LM2596 module is available here (and many other places) : https://www.banggood.com/10Pcs-LM2596-DC-DC-Adjustable-Step-Down-Power-Supply-Module-p-963307.html?rmmds=buy&cur_warehouse=USA
RF4463F30 : https://www.tindie.com/products/NiceRF/rf4463f30-1w-wireless-transceiver-module/
or https://www.nicerf.com/product_179_237.html
About your last question: a NPR client acts as a DHCP server, because inside a NPR network, IP are assigned dynamically among clients, and the protocol do not carry Ethernet overhead but diretcly carry IP packets (therefore DHCP is not relevant in the radio part). I plan to allow "static IP" assignment for clients, but I don't know when I will be able to program it., and/or if the small microconrtoller will have enough ressources.
Richard Green wrote 04/03/2019 at 13:25 point
OK, I'm beginning to get it.  I ran into this once before with an external Wifi-Ethernet bridge called a 'game adapter' which did not carry ethernet MAC of the client across the Wifi link, but chose proxy ARP with its own MAC instead.  Therefore, DHCP server on router would only hand out a single IP lease. Not suitable for multiple client machines at remote end.
  Better to carry full ethernet header within NPR.  More overhead, but more universal application.
f4hdk wrote 04/03/2019 at 16:16 point
@Richard Green With NPR,  can of course put several IP machines (PCs) behind one single client modem. Just set 'client_req_size' to more than one. Take a look at "advanced user guide", especially 'annex 5' and 'chapter 6.2'.
Richard Green wrote 04/03/2019 at 16:29 point
Yes, I saw that.  I still see that as a workaround, a hack, rather than a simple, standards-compliant solution. It would be far better, more adaptable, more universal, if NPR functioned as a fully transparent network bridge in the ISO sense.
RipperFox wrote 04/08/2019 at 02:14 point
About the microcontroller: Ever thought about using an ESP32? I think they are  cheaper and even faster + come with WiFi, wired ethernet can be added with a 1€ board (see e.g. https://sautter.com/blog/ethernet-on-esp32-using-lan8720/)
Thanks for your project!
DL4APT wrote 04/03/2019 at 10:40 point
Nice RF has an aliexpress store: https://de.aliexpress.com/store/1087605 and they also have the RF4463F30 on sale (a lot of them just don't use a space in the name an the search will find a lot or go on the nicerf store to the menue point silconlabs)
Daniel Roseman wrote 04/01/2019 at 01:11 point
Question for you. Does this protocol pause to identify itself? If so, how? What happens if I don't 'set' the callsign in the firmware? I read all of the docs, and I can't find where it identifies itself to the world at large.
f4hdk wrote 04/01/2019 at 04:37 point
Sorry, I'm not sure that I understand the question "Does this protocol pause to identify itself?" English is not my native language.
You can find some answers in the "protocol specification", paragraph 6.3.
Daniel Roseman wrote 04/01/2019 at 20:59 point
Under American law, Amateur radio stations have to pause and identify themselves at least every ten minutes.
47 CFR § 97.119 - Station identification.
https://www.law.cornell.edu/cfr/text/47/97.119
f4hdk wrote 04/01/2019 at 21:04 point
OK Daniel. The NPR modems transmit their callsign (plus the callsign of the peer modem) every 2 seconds. The callsign can contain up to 13 characters.
Do you think that it's enough reguargind the US law that you mention?
robert.ehresman wrote 04/01/2019 at 21:47 point
I do not believe the Who message as described in 6.3 would be compliant station identification in the US. Station identification requires inclusion of the Call Sign. While quite useful, the Who message information would also not be legally necessary here.
Sorry I was typing this while you answered Daniel. 13 characters would be sufficient.
But it sounds like the specification needs an edit.
f4hdk wrote 04/02/2019 at 03:19 point
@robert.ehresman I do not understand your point. Why do you think that the WHO feature of my "New Packet Radio" is not compliant? It already includes the callsign. Refer to §6.2 of the spec also.
fabian wrote 03/31/2019 at 18:19 point
please add linux. And mobile power 24h/365 day
f4hdk wrote 03/31/2019 at 18:46 point
The modem is OS independant. It connects to a host (PC) via Ethernet. Therefore, it is already compatible with Linux.
Have you read all the documentation?
About "mobile power 24h/365d", I have not understood what you expect. Please clarify that.
fabian wrote 04/01/2019 at 11:06 point
comaptible != linux inside and power offgrid
Ken N8KH wrote 03/27/2019 at 02:47 point
I have not yet received an answer to my question: are kits available. Are the motherboard (and daughterboards) available for purchase? How much??
f4hdk wrote 03/27/2019 at 04:23 point
Hello Ken. I'm only a hobbyist, I have other things to do in my life, that's why I don't reply rapidly. Please be patient.
About kits, I don't know if I will be able to ship outside Western-Europe. If someone in the US can organize that for US people, it would be great.
The price for one modem kit is about 80€ here, plus shipping.
Please send me an e-mail to f4hdk[at]free[dot]fr and I will keep you informed. But once again, you will have to be patient, it will take weeks, months to organize that.
Ken N8KH wrote 03/28/2019 at 02:24 point
I'm very interested in this project, and also helping you to write software and/or develop hardware.  I've been interested in high-speed data radio for about 2 decades or more.
I've also looked into the Silicon Labs chip-sets in the past, and found them very interesting.  I'm glad to see that you've taken my ideas with Silicon Labs chips farther than I ever did.
k0elr1 wrote 03/28/2019 at 00:03 point
I wouldn't get too excited about this. By my reading of the US rules (specifically, parts 97.305(c) and 97.307(6), data transmissions are limited to 56 kilobaud and 100 kHz bandwidth in the 70 cm band. I could be wrong, but I'd check before I ordered anything.
Ken N8KH wrote 03/28/2019 at 02:21 point
You are correct.
But it is a stupid rule.  It should be rescinded.
And I understand that it is fairly easy to get an experimental license to operate in (or out of) the amateur bands.  So it could be used under an experimental license.
robert.ehresman wrote 04/01/2019 at 21:02 point
Gentlemen, I direct you here for the 2005 ARRL legal brief position on broadband data transmissions in 70cm as they interpret CFR 47 Part 97.3 FCC regulations.
http://www.ntms.org/802.11/ARRL%20Board%20of%20Directors%202005.doc
Read it yourself, of course, but the summary conclusion by the League legal team is that if a data transmission method MAY be used to carry encoded video combined with other information (whether the video is actually present or not) the FCC would therefore classify the emission as Amateur Television, and the allowable transmission bandwidth can be at least 9 MHz on amateur allocations above 420 MHz. I am aware there are some groups and individuals in the US that have been operating HSMM or Broadband Hamnet style 802.11 based mesh radios in the 70cm band (radios by Xagyl or Doodle Labs) for years. This has probably never been tested in court or as far as I know any sort of enforcement action mind you, but that is why we have the League and why they established such a position at the beginnings of HSMM. Regionally there may be a conflict with common practice such as properly coordinated ATV repeater coverage. I believe effective video teleconferencing has been accomplished at rates well below 500 kbps for decades.
cottsak wrote 03/26/2019 at 06:10 point
What's the point-to-point tested range and some throughput data for said test? Also do you have images of the antennas?
f4hdk wrote 03/27/2019 at 05:45 point
We have not tested maximum distance for point to point links. But you can achieve big distances with high gain Yagi antennas at both sides of the link.
Ken N8KH wrote 03/28/2019 at 02:22 point
My napkin calculations about a decade ago resulted in about a 25 mile range for two stations with 200 kHz bandwidth, 20 W each, and a vertical omni-directional antenna with about 6 dB of gain, and some moderate feedline loss.
f4hdk wrote 03/28/2019 at 13:04 point
@Ken N8KH  about your distance calculation...
Warning, omnidirectional antennas are hard to use at such high Symbol Rates (up to 500kS/s), due to "multipath" issues. You should prefer directional (Yagi) antennas, at least on one side of the link (client side). I will probably add explaination about that inside the documentation.
If you want to discuss more about that, do not hesitate to switch to the "public chat room" of my project.
Ken N8KH wrote 03/26/2019 at 03:35 point
Are kits available for the modem?
shawn wrote 03/25/2019 at 16:38 point
I see you mention a kit in your presentation.  Count me in if you are trying to gauge overall interest.
Stuart Longland wrote 03/24/2019 at 09:05 point
How wide are the channels to produce 500kbps data rates?
f4hdk wrote 03/24/2019 at 09:22 point
Hello, you can refer to the table on page 18 of the "introduction document": RF bandwidth is 750kHz for 500kbps of net-effective datarate, over a 1Mbps channel. It is similar to DATV SR-500kS/s. Like for DATV, we use directional antennas.
