Project Changes and Update:
A project log for (Exosuit?)/VR Controlled Bot
This is going to be a long and hard project - and a really expensive one too. I'm happy to take you along for the ride!
adam-jensenAdam Jensen 04/22/2019 at 04:591 Comment
I have some large changes to how this project is going to work:
First off, I am not sure if i am going to be able to add an exoskeleton feature in this version of the project (more on that later). The process for converting the bot into an exosuit without removing anything for changing operations is too complicated and unimportant in this version
That leads me to my second point, This project will be done in different versions, each one better and more advanced than the one before. This way it is easier to update the project until it reaches a certain point.
Okay, now on to the updates!
I am cutting the frame for the limbs and digits these next two weeks, and I am getting the material for the torso and head. Also, I am testing out the camera-VR headset system these next few weeks as well.
I have decided to use a motion capture system for the robot, instead of trying to create a motion tracking system from scratch. Lets see where this goes!
lawrencesanchez1256 wrote 05/16/2020 at 07:21 point
It proved to be Very helpful to me and I am sure to all the commenters here! It’s forever nice when you can not only be knowledgeable, but also entertained!I had try to promote your own article in to delicious nevertheless it is it seems that a dilemma using your in order sites can you please recheck the idea.This is normally a decent begin, yet in the event that you can't discover anything then you ought to proceed onward to different alternatives and waste no time. While considering an online best essay writing service , assess the creator's accreditations in regards to the topic.
