People Counter
Count people entering and leaving a space through a portal with a low-cost, battery-powered, connected device
We've all heard the bell tinkle at a local shop announcing to the proprietor that a customer has arrived. The bell is inexpensive, lasts forever, and is effective at detecting a door opening. What if the task is both detection and keeping track of the number of people entering and exiting, estimating occupancy, and making this information available on demand via a smart device? Use cases include bathrooms (must be cleaned after every N people), office building conference rooms (only 10 people per month use it? Convert to offices!), museums, factories, etc. Anywhere people come and go and it matters (usually to the building manager) how many go where. Ideally, any device to count ingress and egress events must be small (unobtrusive), low power (run on cheap batteries for years), low cost (we're going to want dozens of them at a site), connected (data collected remotely), and utterly reliable (no false positives/negatives). What are the options? Not as many as you might think..
People counting has a long history which I won't repeat here. There are several available solutions that can be purchased including those using IR emit/detect (so two devices required), cameras and AI (not cheap and cameras present a privacy concern), and even radar (also not cheap). The problem with these solutions is that they don't meet some or all of the (OK, my) criteria for a ubiquitous IoT people counter. Reiterating my ideal design specifications:
1) small and unobtrusive (say, 50 cc or less)
2) ultra low power so it can run on two AAA batteries for 2 years or more
3) inexpensive, say $40 or less BOM cost
4) connected via LPWAN (low-power wide-area network), either LoRaWAN or BLE 5.0
5) utterly reliable, meaning 100% no false positives or negatives
6) no cameras or imagers that might compromise people's demand for privacy (added to the list, but no camera-based technology can meet 2) and 3) anyway).
 I am restricting the people counting I have in mind to a device that counts the number of ingresses and egresses at a portal. Some of the devices mentioned above might do other things as well and could be worth the cost, size, and otherwise be perfectly good products that deserve your attention for whatever use case you have in mind. But for the specific task of counting individual human ingress and egress events at a portal and sending the data via LPWAN to a smart device there are currently no solutions that meet the six criteria above.
This project's goal is to design and test such a device.
In order to reach the goal, the right choice of sensor(s) is going to be critical, so let's start there and consider some of the options.
First, in order to reach acceptably low power operation it is necessary that any sensors have an interrupt. This is because the optimal way to run a low power device is to put the MCU to sleep in an ultra-low power (~2 uA) state until woken up by an interrupt, either a timer interrupt or a sensor data ready or threshold crossing interrupt. So any MCU that lacks a state-preserving low-power mode (like the nRF52 and ESP32) can't be a candidate for this people counter. Any sensor that requires continuous monitoring by a host MCU must also be discarded.  This rules out most analog sensors. And while there are a spectrum of remaining options, I seriously considered only four:
The AMG8833 is an attractive option since although it is technically a camera, it is simply not possible to identify anyone from their 8 x 8 pixel AMG8833 thermal image. So this allays privacy concerns. It has a range from 0 to 5 meters, so can easily detect people passing a portal. The fastest frame rate is 10 Hz, a bit on the slow side for people counting. The AMG8833 has the rather unique ability to generate an interrupt when a pixel exceeds a temperature threshold. Yes, that's right, this device has a pixel-specific interrupt. Once the user specifies a temperature threshold, the user can query after interrupt reception which specific pixel or set of pixels caused the interrupt condition. This is extremely useful for people counting, since typically the set of pixels on one side of the device will reach the threshold condition before the set of pixels on the opposite side of the device providing the directional information required for proper egress and ingress discrimination. We successfully developed a prototype using this sensor (which is an uber-kool sensor to play with in any case) but the Achilles Heel here is power consumption. Normal (continuous 10 Hz) mode uses 4.5 mA, standby mode (0.1 Hz, measure every 10 s and too slow for this application) uses 0.8 mA, and while there is a sleep mode for the sensor the lowest current draw is 200 uA. Ouch!...
Adobe Portable Document Format - 2.07 MB - 03/10/2019 at 03:04
Preview
Download
  • People Counter 2.0
    Kris Winer10/05/2023 at 16:31 2 comments
    October 5, 2023
    The previous version of the People Counter worked as it was supposed to, at least in our limited testing around the house. The device was able to accurately count people coming and going through a threshold, and distinguish between the two. The counts were updated in real time via LoRaWAN to a laptop. So while the device met the "works like" criteria, there were some things needing improvement. First the cost of the two Calipile sensors ($7.58 each per 3000) was too high; ~$15 BOM cost just for the sensors. Secondly, because the temperature baseline has to be frequently reestablshed for maximum accuracy, the average current usage was ~100 uA (~900 mAH per year), seriously limiting battery life. Neither of these is a show stopper, just areas for improvement.
    I tried using the much cheaper AK9754  (now obsolete), which worked well but has a limited range. I also tried using very cheap ($0.85 each per 100) Senba S18 analog PIR sensors. These work well for presence detection and might be able to work to detect ingress/egress. They also consume very little power. However, they are a little on the large side, require a lens for long range,  and being analog, I was never quite convinced of their reliability/accuracy. Still worth a try considering the cost, I just never got around to it.
    Now, ST has introduced their version of a presence detector, the STHS34PF80 This is a single-pixel IR detector with embedded presence and motion detection APIs. I designed a 16 x 65 mm pcba with a form factor to allow easy mounting of an AA-sized 2400 mAH LiSOCl2 battery (holder on the back) with two STHS34PF80 on either end. One tricky bit was the STHS34PF80 only has a single I2C address, so I had to make use of a SN74LVC1G3157DRYR SPDT switch in order to separately communicate with each IR sensor on the I2C bus. I also added a mechanical switch and USB for convenience, a BME280 pressure/temperature/humidty sensor for environmental sensing, and a LIS2DW12 accelerometer for wake on motion. Any or all of these could be dropped in a final production design.
    Digikey has these at ~$3.50 each per 2000 but there is no stock. Mouser prices are ~$5.47 each per 10 in stock. STStore has them for $3.68 each per 500. So the ~$7 BOM cost for the two IR sensors is half the cost of the Calipile.
    Here is a github repository with some sketches showing how to configure the STHS34PF80 IR sensor for basic ambient and object temperature measurements as well as how to configure the embedded function algorithms and use them to detect presence and motion at up to 4 meters range. I also have a basic people counting sketch there which simply shows how to make use of all of the sensors on the board. This lacks the timing comparison that I have used for distinguishing egress and ingress events. But adding this is straightforward.
    Ingress and egress detection works at 2 Hz IR sensor sample rate. This still needs to be optimized to maximize accuracy and eliminate false positives. The scheme relies on sensor interrupt on presence detection and comparison of the detection times to determine the direction of motion. With the RTC alarm period set at once per minute (plenty often for environmental data)  the average current usage is ~19 uA in a one minute window (including one RTC alarm event) and ~31 uA in a ten minute window (including one LoRaWAN event and ten RTC alarm events). These values are the same at 32 MHz and 4.2 MHz CPU speeds since the MCU spends nearly all of its time in the lowest-power sleep state. The average current strongly depends on the IR sensor sample rate and increases as ~2 x ODR, so ~19 uA at 2 Hz becomes ~27 uA at 4 Hz and ~43 uA at 8 Hz, etc. Total average power will also depend on the LoRaWAN duty cycle.
    Bottom line: People Counter 2.0 offers ingress/egress detection at half the BOM cost and at least half the power consumption of People Counter 1.0.
    The next step is thorough...
  • A Word or Two About Power Usage
    Kris Winer02/01/2020 at 01:24 0 comments
    January 31, 2020
    One of the design criteria is that the People Counter should last two or more years on two AAA batteries. This is about 1200 mAH capacity at 3.0 V, so two year battery life would mean an average current usage of:
    1200 mAH/(2 Years x 365 days/Year x 24 H /day) ~ 69 uA,
    which isn't easy to achieve.
    I measured the power usage of the People Counter under conditions known to minimize power usage including 4.2 MHz clock speed, "fastest" Arduino compile optimization, and 10 minute LoRaWAN duty cycle.
    The variable was the period of threshold adjustment, either once every 10 seconds or once every 20 seconds. The former is about the fastest one needs to adjust the threshold since the Calipile sensor drift is <1 count/second.  Adjusting the threshold every 20 seconds saves a significant amount of power but runs the risk of the threshold lagging the sensor baseline and introducing inaccuracy in the transit detection. For most applications, I would expect the "sweet spot" to lie between 10 and 20 seconds.
    I measured:
    <166 uA at 10 second threshold adjustment period
    <106uA at 20 second threshold adjustment period
    These currents are the average current after one hour of operation and are upper limits, since the average current will continue to decrease with time until it asymptotes. What this means is that the threshold adjustment uses on average ~120 uA of current at 10 second period, and the rest of the ~46 uA is the cost of the LoRaWAN, sleep current of the STM32L082 and the current to power the sensors. The latter (~40 uA) is consistent with my experience measuring the power usage of similar devices (like the Bin Level Monitor).
    So the threshold adjustment is using the bulk of the current in this application and increasing the period to more than 10 seconds is the way to eke out more battery life. But this will eventually come at a cost of accuracy, just at what period and how much loss of accuracy we do not know yet. I would guess that a 20 second period would probably be OK in most cases but I don't know what might happen with longer periods. More testing will tell.
    So at 10 second threshold period, two AAA batteries would last ~300 days and at 20 second interval, 472 days. So we are getting close to the power usage goal; at 20 sec period two AAA batteries could last ~1.3 years.
    But these are baseline numbers, and battery lifetime will be less depending on the number of people "counted" each day. At 10 second period, the threshold adjusts 360 times an hour, which costs 0.12 mAH. Assuming counting a person uses as much power as a threshold adjustment (a good assumption), then counting one person costs 120 uAH/360 ~ 0.33 uAH/person.
    So counting 100 people per day will cost an additional 0.033 mAH per day and reduce the battery life from ~300 days to ~298 days, barely noticeable.
    Counting 1000 people per day will cost an additional 0.33 mAH per day and reduce the battery life from ~300 days to ~278 days, about ten percent.
    Lastly, counting 10,000 people per day or 1250 people per hour during an eight-hour business day (pretty heavy traffic for, let's say, a bathroom) will cost an additional 3.33 mAH per day and reduce battery life from ~300 days to ~164 days, about half.
    Of course, proof is in the testing and while we can measure the power usage of individual units and make projections like those above all day long, we really need some real world results to better judge accuracy and battery life.
  • More on Threshold Drift​, Test Results
    Kris Winer01/27/2020 at 20:26 2 comments
    01/27/2020
    Using the new method of testing the People Counter in the intended operation mode while connected to the serial monitor I captured more data over a longer term to measure threshold drift and its effect on counting accuracy. First, I streamed data for 20 minutes at 10 Hz and walked under the People Counter (mounted on the upper jamb of a portal) a total of six times, twice every 10 minutes or so.
    The ingress and egress events were captured with 100% accuracy (6/6). There was significant drift in the baseline of the sensor signals, and the threshold adjustment method was able to keep track well enough to allow the People Counter to maintain its accuracy over the entire 20 minute interval. I suspected that the baseline rise at about the 10 minute mark was due to the house heater coming on, which I verified in the next test.
    In the next test, I changed the serial monitor output rate to 1 Hz and collected data for 120 minutes, again walking back and forth under the People Counter at least twice every ten minutes or so.
    The sensor signal baseline dropped rapidly as soon as the test started then slowly climbed again. At the 37 minute mark I turned on the local heating system and turned it off at the 54 minute mark. The effect in increasing the baseline is obvious. The 1 Hz serial monitor sample rate is not fast enough to capture the full transit excursions in each case (which is why some of the peaks appear to be below the thresholds) but I counted 30/29 ingresses and 28/29 egresses; one of the transit directions was reversed. So no false positives, 100% transit crossing detection, 96% direction detection success rate in this 2-hour test.
    Even though I expect that the sensor baselines will eventually plateau (to be demonstrated) I also expect that changes in the building heating system and even the presence of people crossing the portal will affect the baseline so that threshold management will always be required to maintain accuracy. It seems to be working pretty well on these time scales. That is, the baseline changes are rather slow and smooth, and the threshold adjustment method can easily compensate.
    So where are we in this project development? Here are the design criteria with commentary:
     We are using a ~105 cc Bud Industries container.
    Average power usage at 10 minute LoRaWAN duty cycle is ~150 uA; two AAA batteries (1200 mAH) will last one year.  The power usage is significantly impacted by the threshold adjustment requirement. It will also depend on the people counting rate since everytime a person crosses the line-of-sight of the device costs power, so the heavier the traffic the lower the battery life.
    Initial production cost was higher, the cost per device should drop with higher production volumes such that the first 500 should cost less than $40 each.
    LoRaWAN with excellent range.
    0% false positives. 96% accuracy with limited testing. The accuracy is for a portal that is 7 feet tall and 2 - 3 feet wide, a normal household door. We haven't tested the device in other environments or with different portal designs so the ~100% detection accuracy could be lower.
    No camera.
    Next step is deployment in the field for more rigorous testing in the intended operation mode. I will report on this next.
  • Optimization and Testing
    Kris Winer01/26/2020 at 19:07 4 comments
    January 26, 2020
    I haven't posted anything on this project for a while as I was busy with other things. But I have recently had occasion to revisit and I have made some progress in understanding how best to use this device. The kind of testing I had been doing was either 1) looking at copious output on the serial monitor upon egress/ingress detection on the bench or 2) installing and simply using the device to count egress and ingress transits reported via LoRaWAN. The trouble is that things mostly work in mode 2) but when they didn't I couldn't really diagnose the problem.
    For this round of tests, I mounted the device on the entrance way between our Hall and Dining Room where I work in such a way that I could maintain the serial tether to the laptop and record the details of the sensor device while I walked under the PeopleCounter. I streamed object temperature, object temperature theshold, and ingress and egress counts at rates from 10 - 80 Hz, captured the data from the serial monitor and plotted the data in a spreadsheet. This is a typical result:
    The way the PeopleCounter works is that the sensors detect when a warm human crosses their line of sight, the time difference in the detection determines the direction of the transit. Simple. The sensors allow a threshold to be specified so that an interrupt is generated upon crossing the threshold, either upward or downward crossing. I have been using about 200 counts as an upper threshold to detect people crossing at a distance of ~1 - 2 foot from the sensors (where the head and shoulders are, more or less, when the device is mounted on an upper door jamb). The problem, as can easily be seen, is that the sensor responses drift, and if the baseline isn't corrected every so often, the drift will result in a large enough separation between the transit excursion and the threshold that it will never be crossed and the device will stop counting.
    The threshold, then, has to be reset at a fast enough rate to keep track of any baseline drift but not too fast to cause a large power drain on the battery. But there is a problem here as well. If the threshold adjustment happens to coincide with a person transiting the device (as in the fourth peak in the figure), the baseline reset can be skewed upward. So some limit needs to be applied. Threshold management turns out to be critical to obtaining accurate performance. I expected this from the start, but didn't realize how difficult it would be to find a 100% accurate solution.
    The good news is that the people counter accuracy is > 90% in simple tests that I can do around the house. We are about to test it "in the field" and will have data from more realistic deployments soon. I expect to learn a lot more about how such a device might behave in less controlled environments.
  • Packaging Matters!
    Kris Winer03/25/2019 at 01:09 0 comments
    24 March 2019
    I am still not sure exactly why, but the People Counter just doesn't like the smaller Hammond box. Maybe it's because the sensors are so close to the sides of the box that prevent them from working well.
    In any case, I put the new board into the old Bud box and repeated the testing from yesterday and I was very happy to find that the new People Counter pcb with the same old program and Bud box worked at 100% accuracy. I tried five passes (ingress + egress) myself (5' 11") and captured all 10 events. Then I asked my wife (5' 6") to try a couple of times and was able to see her two ingresses and two egresses. Then one more time with me following close behind her on the way in and on the way out. The People Counter captured all events in the proper order. It's like magic!
    The Bud box is not a bad option (well, it's the only one that works so far!). It's a bit bigger than I was hoping to get away with, but the advantage of the larger size is I can use two AAA or AA batteries instead of a coin cell to extend the time between battery changes. At the measured < 50 uA average current usage, two AA batteries provide (2400 mAH/0.05 mA) about 5 years of service. Lighter AAA batteries about half that. Pretty close to set and forget.
    I am gratified that the pcb design and firmware I developed seem capable of repeatable 100% accuracy. I was afraid I had a one-off on my hands.
    I need to make a few sets of these People Counters using the Bud box and deploy them in a test friendly environment to get some real-world test data. I will likely ask my machinist friend to drill the holes for me to make sure these are all the same. I have some likely venues for this next stage in testing. More to come....
  • Second Test with New Design
    Kris Winer03/24/2019 at 02:38 0 comments
    23 March 2019
    Having fixed the hole placement by redesign I assembled the new pcbs I received from OSH Park and tested the performance using the existing program that worked so well on the first test. Plug and play, I hoped....
    The first thing I tried was relatively small holes for the thermopile sensors (bottom case side) but I didn't record any entries or exits on the first few passes so I enlarged the hole sizes to match what I used on the previous test (top case side).
    I am using the same coin cell battery plus jumper for power but now a chip antenna instead of the copper monopole. I noticed a significant degradation in the RSSI signal with the board mounted in the case and the battery sitting on top of the board. I think this huge hunk of steel right next to the antenna stay out zone is costing me range. I might have to return to the monopole which seemed to work pretty well, which would also save some cost.
    I like this smaller Hammond container:
    It's about half the size of the Bud box. But while the Bud box can accommodate two AA or two AAA batteries plus holder the smaller Hammond box can only be powered by the 950 mAH coin cell battery.
    How did it work?
    Plug and play...Not!  Even with the larger holes I often missed completely one or two out of the five passes back and forth that I used as a test run. Occasionally, I would register two ingresses when one each ingress and egress should have been measured. There is something different between this assembly and the previous design even though placement of the Type ABZ module and Calipile sensors on the pcb is identical. The mounting, container and holes are different (even though the same diameter) resulting in a difference in the field of view that must matter. One possibility is that my criterion for signal correlation is too strict, which works on one design but not another. What this means is I need to go back to diagnosing in detail what is happening with this particular device and see if I can get it to work well.
    It would be fine if I needed two sets of criteria one specific to each container. better if I could find settings that worked well for both.
    It is not surprising to see such sensitivity to externals like packaging especially with optical (or IR anyway) devices. I would have been surprised (although happy) if this device had worked at the same 100% accuracy of the first one. Beginner's luck I guess...
  • First Test of People Counting
    Kris Winer03/13/2019 at 22:19 0 comments
    March 13, 2019
    I soldered on an 82-mm-long,  insulated, 26-gauge copper wire as a simple monopole antenna, added LoRaWAN Tx at one-minute intervals to the People Counter sketch and plugged in the 3V, 950 mAH Renata battery.
    I used Scotch tape to mount the People Counter on my bedroom door frame such that the door could close and not interfere with the container. This is how I would expect the People Counter to be mounted "in the field".
    The door frame is at a standard 7-foot height, so when I walked through it the sensors would be about 30 cm from my head and 50 cm from my shoulders. I assume my head is what would trigger the ingress/egress detection.
    After testing with a handwave on the workbench I installed the device on the doorway frame and proceeded to walk through the door, wait a minute or so, and then walk out the door and check the Cayenne dashboard to see if the latest trespass was captured by the People Counter. At one-minute Tx intervals, I usually saw the ingress on the dashboard when I returned to the workbench and could sit and wait until the egress showed up. Pretty exciting!
    Somewhat to my surprise, each of five passes through the threshold and back again registered as it should and I had captured all five of each ingress and egress with 100% (OK, 10/10) accuracy.
    Ingress:
    Egress:
    So I am pretty happy with this simple test of performance.
    There is more extensive testing needed, of course. I suppose I could stand at a portal at a store somewhere with a counter and manually mark entrances and exits and then compare with, say, an hour's worth of data from the People Counter.  After such testing, I am sure there would be some fine tuning needed. For example, the sensitivity of the threshold detection might need adjustment; the LoRaWAN Tx duty cycle needs to be selected for the particular use case.
    At this point, I am interested in generating failures of the counter to work. The portal I selected for the first test is too narrow for more than one person to even try to pass at the same time, and this is where this kind of people counter is intended to be deployed. But what about performance when people of different sizes pass through, or people wearing hats, or who knows what. I need to generate a more realistic test to find out where this kind of device might fail and augment the sketch to deal with such situations properly. It is unlikely that in a real deployment the accuracy would remain at 100%.
    But this is a good first start...
  • First Build and Power test
    Kris Winer03/10/2019 at 01:25 0 comments
    March 9, 2019
    First builds are always fun. It's where you find out where the mistakes are.
    I received my first iteration of the People Counter pcbs from OSH Park and immediately tried the fit into the two low-cost containers I plan to use for this project. One is the Bud Industries HP-3649-B costing $1.30 each per 100, and the other is the Hammond 1551-HBK costing $1.61 each per 100. Fit into the Bud box was as expected since I had tested this on other projects and hadn't modified the design of the mounting devices (quarter circles) on the pcb. I did however change the position of the holes for mounting into the Hammond box without realizing that they are asymmetrically placed with respect to the pcb edges. So the People Counter fits fine on the Hammond box mounting posts if I install it upside down!  I redesigned the board for proper hole placement, having to move some edge pin ports around to do so, and resubmitted to OSH Park. In the meantime I will use the Bud box for testing and optimizing function.
    The Bud box is roomy and affords space for 2 AA batteries and holder.
    It took me about an hour to assemble the relatively simple board. Here is what the assembled pcb looks like:
    Programming is through the SWD port on pins D8 and D9 using an ST-Link V2 I bought from e-bay. I used the "ST Link (STM32L0)" programmer selected from the tools menu in the Arduino IDE and the "Upload Using Programmer" method in the Sketch pull down menu. On this device, I need to use a jumper to pull the Boot pin (BTN, which is also a user button on D2) HIGH to put the STM32L082 in boot mode to allow programming. Not as convenient as using on-board buttons and USB connectors but it worked well enough.
    Serial output for debugging was available via Serial 2 on pins A2/A3. I have a blue led on pin D10 (shared with SPI nCS) for indication as well which helped make sure things were happening in the sketch as they should.
    I am using the Murata CMWX1ZZABZ (STM32L082 + SX1276) as host MCU and for LoRaWAN connectivity. LoRaWAN is ideal for low data rates and infrequent messages. This application needs to send just a few bytes every so often (1 or 10 minutes intervals, for example) to the LoRaWAN gateway ("I got three ingress counts and 6 ingress counts since the last update!"). It could also send a LoRaWAN Tx message every time it detects an ingress or egress event.  I am not sure this would work well in a situation where a LoRaWAN Tx message had to be sent every time someone entered a big conference room as it filled up for a meeting. My preference would be to update the egress and ingress counts on a periodic basis, like once a minute, but only if there was a change since the last update, and otherwise every 10 or 30 minutes. The Tx strategy will depend on the use case and the customers' preference.
    The two Calipile (TPiS 1S 1385) thermopile sensors are placed as far from each other on the pcb as I could manage. The diagonal placement also insures the orientation of the box doesn't matter except to properly identify which direction is egress and which is ingress, but this is arbitrary. Might as well be directions 1 and 2. The Calipile's have address pins to allow up to four on a single I2C bus. These are set to respond to I2C addresses 0x0C and 0x0D. These have dedicated interrupts as well which ensures the temperature threshold crossing events are properly attributed to the corresponding sensor.
    There is a PTH for soldering an 82-mm copper wire as a LoRaWAN monopole antenna. Later designs use a chip/pcb antenna. There are two PTHs for mounting the 3V, 950 mAH CR2477NAH I plan to use when deployed. Finally, there is a secure element ATECC608A to allow secure boot, secure LoRaWAN provisioning and key storage, as well as secure FOTA when these are deployed in the "field" (office building, hospital, factory, etc.). Security is often neglected in IoT devices and it is not straightforward...
View all 8 project logs
Jim Me wrote 02/04/2024 at 23:44 point
Kris,  I appreciate your comments and concerns mentioned!
+ I will be glad to share my code with you once I get it to an "adequately working" condition.  It is not nearly as elegant as your code, but will be working in my prototype (with RAK Wireless RUI3 based code for LoRaWAN communications to my ChirpStack Gateway).
+ Once I get my STHS34P80 parameters tuned with Fresnel lens in place, I can try with just a reduced aperture.  My thinking is the Fresnel lens reduces the FOV while maintaining the full amount of photons to the sensor (hence the specified increased range which I do not need).  Plus the lens acts as a "dust cover" over the STHS34P80 which has some benefit.
+ The "wishful thinking" of an ML approach is the ability to assess ingress/egress progression  across the two sensors FOV beyond the "fixed" threshold for STHS34P80 "presence" determination or "fixed" parameters for the STHS34P80 filtering algorithm, hysteresis, etc.  I can make the threshold for interrupt very sensitive and with enough training, the ML inference MAY be better at identifying motion thru the two FOV regions based upon the thermal values read from each STHS34P80, particularly as the environment background thermals vary ?
+ I've yet to wrap my head around how the STHS34PF80 ability to provide "motion" and "shock" detection might be used to increase accuracy;  perhaps they may be usable to reduce "false positive" detections?
+ I don't expect the MCU to be awake too much longer for each ingress/egress event, with the STHS34P80 configuration and LoRa transmissions to still dominate the average power consumption. But as you mention, a Nordic Power Profiler evaluation will be needed to quantify.  In my case 3 x AA or even 4 x AA or similar is a viable part of my design tradeoff decision.
Please continue to stay tuned...
Jim Me wrote 02/04/2024 at 18:17 point
Hi Kris.  I'm back onto this ingress/egress project.  My current exploration of ingress/egress detection with the STHS34PF80 sensors is now pursuing the following course of action after being inspired by your project.  I have dual sensors spaced ~2 inches apart.  I've placed a Fresnel lens in front of each sensor to narrow their FOV to better define independent detection zones.  Rather than just look at the sequence of each sensor's interrupt on Presence detection, I am trying to maximize accuracy by tracking passage thru four states in proper sequence.  Specifically, using state machine logic after awakening from interrupt that watches for the first sensor presence, then both sensors presence, then just the second sensor presence, then neither sensor presence to validate ingress/egress.  So if a person starts to enter, but retreats, they are not counted.  I have next to work on optimizing the various parameters of the STHS34PF80 algorithm and sampling and evaluate with real environmental conditions.  Once I have my ingress/egress algorithm "tuned", I ultimately want to train a ML inference solution and compare accuracy results.  I'm using a RakWireless RAK3172 WisDuo LPWAN Module I had on hand as the MCU and LoRa Radio so the whole solution may become a viable battery powered solution (depending on optimal STHS34PF80 settings).
Kris Winer wrote 02/04/2024 at 18:29 point
This seems like a more robust detection algorithm. Once you get it working I hope you will share it with me so I can try it out on my PeopleCounter. I am sceptical that ML will improve the accuracy but I am ready to be convinced with results. Great thing about the RAK3172 is that the modules are cheap, if a little larger than I prefer. So you could end up with a low-cost, accurate ingress/egress detector. Are the Fresnel lenses any better than just using a hole in the container as a FoV restriction?
Kris Winer wrote 02/04/2024 at 18:35 point
The advantage of the interrupt-based approach is that the MCU is only awake for a very short time. I wonder if the state-based algorithm results in more power usage and, therefore, a lower battery life. I'd be interested to know how the average power usage changes once you get around to measuring it...
Kris Winer wrote 07/19/2023 at 21:24 point
Just in case anyone is still interested in this project, I am working on a [PeopleCounter.v02](https://oshpark.com/shared_projects/300zhmWZ) using [this](https://github.com/kriswiner/STHS34PF80) new ST IR sensor which has internal temperature compensation like the AK9754 (now obolete) and a more or less reliable embedded presence detection algorithm. My hope is to have this working at an average current usage of ~25 uA or so, much lower than the ~100 uA of the Caliple -based solution. The sensors are also cheaper than the Calipile sensors. Lastly, I have designed the latest device to work with an AA-sized 3.6V, 2400 mAH LiSOCl2 battery for > 10 year lifetime. I will document the build and test results for this new device in the project logs in the next few weeks.
Jin wrote 08/11/2023 at 04:10 point
Hey Kris, I'm following and interested in this project. Just ordered a few of the new
PeopleCounter.v02 boards. I'm looking to use this to help my local dog park with some data. I'm pretty new to this however so forgive my basic question - Is there a new item list that goes with the v02 Project or should I just get all the items from v1?
Thanks in advance.
Kris Winer wrote 10/04/2023 at 00:28 point
Sorry I missed this comment. The PeopleCounter.v02 board is completely different in terms of components, etc. Is this what you are asking? If interested I can send you the BOM. Just send me an e-mail at tleracorp@gmail.com with the request. I haven't done much with this lately after getting the basics to work. I still need to test for efficacy, detection rates, and false positives, etc. I'd love to have some help in testing so please let me know how I can support your work.
Jim Me wrote 10/04/2023 at 00:23 point
Kris,  I will follow your evaluation of the ST STHS34PF80 with keen interest.  I've ordered your adapter board from OSHPark and a couple of the IR sensors myself. My application is person presence monitoring, either by direct sensing or ingress/egress monitoring.
Kris Winer wrote 10/04/2023 at 00:32 point
The sensor is pretty useful by itself, that is, just as a presence detector (not sure about the moton detection part, I am not really using that). You might not need two as I have to detect presence, although there are cheaper solutions out there (some of the Chinese IR sensors are < $1 each). The harder parts are 1) detecting direction of motion, so ingress/egress 2) at low enough power to make a battery-powered solution attractive. I think this sensor has the capability to do this. The claimed 4 meter range certainly will help. If you have any questions about how to get the sensor to work please let me know how I can help at tleracorp@gmail.com.
agerl wrote 08/30/2021 at 16:15 point
Hi Kris! Is there a reason why you didn't use the integrated presence detection functionality based on the delta of the object temperature low pass filters? This would save you from having to wake up the host every 10 or 20 seconds.
I also saw that you are looking for a cheaper solution. I think the price for the CaliPile at higher quantities is quite reasonable. What is your desired cost for the sensor?
Kris Winer wrote 09/03/2021 at 00:50 point
We looked at almost every way to use the embedded functionality of the Calipile for directional presence detection and people counting. The biggest problem we had was that the average temperature would drift, sometimes quite a bit. So this required that we periodically recalibrate the baseline to be able to detect temperature excursions caused by people in the field of view. No amount of low pass (or other) filtering was as reliable and accurate as simple using the moving average of the baseline temperature, i.e., doing this manually. As for cheaper sensors, there is the AK9754 which does about as well as the Calipile at half the cost and at a bit less power. The embedded baseline drift cancellation of the AK9754 does well enough, but for both of these solutions the reliability is less than the 90% we were hoping for.
TactiZity wrote 12/27/2020 at 12:11 point
Hi, is it possible to test this board?
Kris Winer wrote 12/27/2020 at 17:57 point
Yes, we have tested this board many times.
TactiZity wrote 12/30/2020 at 11:20 point
Can I buy one, I mean?
Gerardo wrote 12/01/2020 at 20:48 point
Hello Kris, I'm an IoT developer and would like to know the development stage of this solution. Thanks in advance
Kris Winer wrote 12/27/2020 at 17:59 point
We have prototypes using various technologies. Our goal is to cut the cost by finding cheaper sensors that can work as well as the Calipile sensors while keeping the power usage tiny. We're looking for additional partners to help bring the technology to the market.
Pascal Mattes wrote 09/14/2020 at 11:07 point
Is there any update on this project? Sounds interesting and would love to get one for myself.
Kris Winer wrote 10/17/2020 at 15:34 point
Still working on lowering BOM cost and improving accuracy. Not quite ready for sales just yet.
I have sent out samples to several people for testing and I am awaiting results.
I would be interested in finding additional commercial customers to help me take the project over the finish line...
Jim Me wrote 01/26/2020 at 00:57 point
Kris, or anyone following Kris' People Detection project:  Have you done any evaluation or experimentation with the Doppler RADAR Motion Sensor?  I see the RCWL-0516 PCBA has some potentially interesting specs (e.g. range, 360 degree FOV, 4-28V, Interrupt pin, cheap, enable pin for power reduction, can be sealed in case)??  I am considering evaluating it versus the AK9753 4IR sensor (perhaps including both in a sensor node to improve reliability of operation.).
Kris Winer wrote 01/26/2020 at 01:04 point
I haven't looked at it but the 2.8 mA operating current is the deal killer for me. This would use ~67 mAH per day so would last just 14 days on the 950 mAH Renata coin cell battery I am using. Compare against the ~10 uA used by each Calipile and the 9 - 12 month battery life I expect in typical use cases.
Jim Me wrote 01/26/2020 at 01:16 point
Kris, thanks for the prompt reply! I concur with the power consumption issue. I am thinking of limited power on time of a RCWL-0516, used to confirm the triggering of the AK9753 (IR sensor). Your dual Calipile approach is tempting! The apparent complexity of tuning the Calipile to different environments concerns me, and the cost (using two Calipile) is a concern (somewhat offset by potential for long battery life!). In my application, using a pair of AAA or even AA alkaline batteries is acceptable. I am happy to share any learning if/as I pursue my investigation further.
Kris Winer wrote 01/26/2020 at 04:21 point
For people detection the tuning turns out to be pretty straightforward. The hard part is drift compensation, but even this is manageable. Agree, the Calipiles are expensive at ~$8 each, it makes the People Counter device cost more than I would like.  Small, cheap, or fast (or low power, in this case), pick any two....
Jim Me wrote 01/26/2020 at 17:45 point
Kris, FYI and based upon your comments, as my next step in sensor tech evaluation, I've ordered a Excelitas Calipiles DemonKit adapter of the TPiS 1S 1385 and also a Grove Module of the AKM AK9753 4 IR sensor.  I've also ordered a few of the cheap RCWL-0516 3.2GHz microwave Sensor boards to play with (to see if they can be used in a gated power mode to overcome their current draw).
Kris Winer wrote 01/26/2020 at 18:33 point
Are you just playing around or do you have an application in mind? If you want to discuss in more detail than possible here send me e-mail at tleracorp@gmail.com.
yyhhgg wrote 12/04/2019 at 11:49 point
Do two or more people go through accounting?
Kris Winer wrote 12/04/2019 at 17:51 point
I haven't tested the discrimination possible with multiple people. Presumably, if there is enough separation between the people, they would register as two events. But I don't know what this separation in distance/time might be. This device is more properly a threshold crossing counter rather than a true people counter; that is, it cannot count thenumber of people in a room at any give time, for example. But it can discriminate between relatively hot humans and relatively cold things, so only counts threshold crossings by people (and maybe animals).
Cliff wrote 05/24/2019 at 11:09 point
Any progress on the project? Also do you have any tips on where to get the TpiS sensor? I have only found it as bare chips on my searches. If you want I could send you the code that ST used for the vl53l1x for their people counter demo.
Kris Winer wrote 05/24/2019 at 16:52 point
I haven't been spending much time on this lately since I got the device to work more or less. It is still not as robust as I would like and I need to optimize the temperature thresholds, etc. But phase 1 let's say, of showing proof of principle with this design, is a success. Not sure what you mean by "bare chips"; I bought mine from Digikey (https://www.digikey.com/product-detail/en/excelitas-technologies/TPIS-1S-1385/1601-1012-6-ND/9760643) and they are in stock if rather expensive for just a few. Yes, I would like to see the code ST uses for their people counter, thanks. I am at tleracorp@gmail.com.
Dan Maloney wrote 02/27/2019 at 17:55 point
I recall a certain mall department we'd visit back in my youth. They had some sort of traffic counter at the entrance from the mall, must have been ultrasonic because I could hear it loud and clear and it was painful as hell. That was with tender ears; I doubt that accumulated damage from a LOT of concerts and five decades of entropy would still make me sensitive to such a device.
Long way to get around to saying that I wonder if ultrasonic transducers could help.
Kris Winer wrote 02/27/2019 at 18:07 point
Yes, and these are still used in commercial people counters today, one of a variety of methods. I didn't reference them all. They suffer from some of the same problems that the other technologies do, they are typically large in size (not a show stopper) but also require a fair amount of power to run.
But the other problem is they will detect both humans and inanimate objects crossing their path and can't distinguish between them. This is a problem for the VL53L1 ranging sensor as well. This is the advantage of a temperature-based scheme. But in the end, it is practical counting estimation we are after so even a 95% accurate solution will work.
The deal killer for most candidate sensors as part of a remotely-placed, battery-powered people counting device is power usage. Not many sensors of any type have continuous power usage numbers around 15 uA...
Kris Winer wrote 02/27/2019 at 03:54 point
Thanks Greg,, I'll take a look...
"Is privacy really a concern if there is no storage and you do not broadcast the images? "
Yes, not just personal privacy but a lot of potential customers don't want anyone taking pictures of their sensitive operations, facilities etc. They just don't like cameras, no matter what you tell them.
FPGA? Can I use their camera module with an STM32L4?
1 mW is still 300 uA, so not low power from my POV. I am shooting for 0.165 mW
greg wrote 02/27/2019 at 03:36 point
I think an imaging solution can meet your requirements.
Lattice has an example:  http://www.latticesemi.com/Products/DesignSoftwareAndIP/IntellectualProperty/ReferenceDesigns/ReferenceDesign04/HumanPresenceDetection
The development kit is near your price target:
http://www.latticesemi.com/en/Products/DevelopmentBoardsAndKits/HimaxHM01B0
It consumes 1mW so you should be able to run for a couple years from a couple AAA.
