Circuit parameters
A project log for Mains protection box
Work more safely with mains power
yann-guidon-ygdesYann Guidon / YGDES 05/15/2019 at 01:250 Comments
Before powering it on for the first time, it's good to test all the parts and their connections, which is also a great opportunity to measure all the parameters :-)
Primary : 3 ohms, approx. 3.3 Henrys (disconnect the variac !)
Secondary : 4 ohms, approx. 3.8 Henrys (it seems to drift ???)
Between primary and secondary : > 2G ohms but 1.5nF...
The secondary is connected to quite a few things:
Let's see the incandescent bulbs : I measure the "cold" resistance
The variac is a different story, because it's variable...
