Esp little game engine
Game engine using a virtual machine with a simulator and a web compiler
Public Chat
Game engine with web emulator and compiler. The image is displayed on the tft using the TFT_eSPI library
https://github.com/corax89/esp8266_game_engine
The game engine has a virtual screen resolution of 128x128 pixels, 16 colors, one background layer, 32 soft sprites with collision tracking and rotation, 20kb of memory for the game and variables. The virtual machine performs approximately 900,000 operations per second at a drawing rate of 20 frames per second. Control of eight buttons.
The online compiler of the C subset to the assembler, and then to the virtual machine code.
Portable Network Graphics (PNG) - 283.77 kB - 03/15/2019 at 14:05
Preview
Download
  • 1 × esp8266
  • 1 × tft 240x320 ili9341
  • 1 × PCF8574 Microprocessors, Microcontrollers, DSPs / Microprocessors (MPUs)
  • 1 × gameboy case
View all 8 project logs
mystboy666 wrote 05/10/2019 at 09:54 point
Hi there!
Is there any plan supporting these small monochrome oled displays?
Thanks!
Igor wrote 5 days ago point
I did not plan this, but it is possible.
Hendra Kusumah wrote 04/23/2019 at 06:26 point
hi there, just try out your firmware and it work. But I use a different kind of ili9341 board and the screen got flipped upside down, is there anyway to change/flipped the screen orientation?
Hendra Kusumah wrote 04/23/2019 at 06:29 point
I am using this board:
https://www.tindie.com/products/thirtytwoteeth/game-boy-zero-handheld-edition/
since it is basically an ili9341 breakout without the pi zero I manage to get it running but there is the problem I mention above
Igor wrote 04/23/2019 at 18:13 point
In the setup () function, find tft.setRotation (1); and change to tft.setRotation (3); Or try to substitute other values from 0 to 3
Hendra Kusumah wrote 04/24/2019 at 06:12 point
Ok, it works. Thanks for the follow up
l3pr3ch4un wrote 04/04/2019 at 07:34 point
Anyone is interested in Wii nunchuck support (I didn't have any pcf8574 laying around..)?
Igor wrote 04/04/2019 at 16:59 point
Here I found the instructions for connecting. This is i2c so the scheme does not change. Need to rewrite the button processing code. https://www.instructables.com/id/ESP8266-and-Visuino-WiFi-Remote-Control-Smart-Car-/
l3pr3ch4un wrote 04/04/2019 at 18:40 point
Yup, already done it, code can be found in:
https://github.com/mali1741/esp8266_game_engine/tree/nunchuck
l3pr3ch4un wrote 04/03/2019 at 15:18 point
Nice project! I've had some problems running some of the games (mars and breakout) on the esp, and found that setinterrupt in cpu.ino didn't use the stack as in cpu.js .  When I changed it to behave like in cpu.js it works fine though.
dan wrote 04/03/2019 at 22:52 point
Im have issues with running games on my ESP hardware also. Can you explain more in detail what you did to fix this problem.
l3pr3ch4un wrote 04/04/2019 at 07:17 point
I can get a github pull request out tomorrow, but until then:
in cpu.ino:setinterrupt
shadow_reg[0] = flagsToByte();
for(int8_t j = 1; j <= 15; j++){
shadow_reg[j] = reg[j];
should be changed to:
reg[0] -= 2;
writeInt(reg[0], flagsToByte());
reg[0] -= 2;
writeInt(reg[0], reg[j]);
and the op return code 0x9A:
for(int8_t j = 15; j >= 1; j--){
reg[j] = shadow_reg[j];
byteToFlags(shadow_reg[0]);
should be changed accordingly:
reg[j] = readInt(reg[0]);
reg[0] += 2;
byteToFlags(readInt(reg[0]));
reg[0] += 2;
Besides that there are a few cpu-instructions that handles sprites that need a limiter of the spite index ( & 31  as most of them already has).
l3pr3ch4un wrote 04/04/2019 at 18:39 point
Igor wrote 04/04/2019 at 17:02 point
Strange. This should not be a problem. Interrupt handling through additional registers faster.
l3pr3ch4un wrote 04/04/2019 at 17:44 point
Yes, I agree. Somehow I got a full interrupt queue with the shadow reg code.
l3pr3ch4un wrote 04/04/2019 at 21:22 point
So I found the error, the reg and shadow_reg arrays are one element short!
int16_t reg[16];
int16_t shadow_reg[16];
should do the trick!
Igor wrote 04/08/2019 at 06:09 point
Thanks!
Mr Rockgovsky wrote 04/01/2019 at 09:07 point
I'm not sure how I'm supposed to run this thing - I uploaded the game.bin file to the esp8266,
but don't know what else should I do/how to proceed.
I've also struggled to hook everything up properly, and I'm not sure if I've done everything correctly. Could you provide a more detalied schematic? Thanks in advance, very nice work!
amera64 wrote 03/19/2019 at 06:04 point
I have everything hooked up and firmware loaded but can't figure out how to load the .bin file into the Esp8266.  Can anyone point me in the right direction? Thanks
Igor wrote 03/21/2019 at 19:42 point
https://github.com/esp8266/arduino-esp8266fs-plugin
All uploaded files must be in the data folder.
tormozedison wrote 03/12/2019 at 20:17 point
Cool! A project with open source firmware, but top secret circuit diagram. Why?
Igor wrote 03/15/2019 at 13:00 point
Nothing secret. Just a screen on spi and a keyboard on i2c
tormozedison wrote 03/15/2019 at 21:04 point
Thanks. Take a look at this review:
https://habr.com/ru/post/443918
