YATAC78 - Yet Another TTL Archaic Computer (1978)
The system bus is clocked at 16MHz and an example CPU instruction spans 4 clock cycles as follows:
  1. Load Instruction from ROM.
  2. Read data from source register or RAM.
  3. Perform an ALU function using the ROM as lookup table.
  4. Write data to accumulator, a register, and optionally to RAM.
The alternating use of both ROM and RAM allows a second processor to be added to the system. Both processors use dedicated pipelines to cache data between the alternate program and data address spaces. One processor handles serial communications and general computational tasks (CPU) while the other is dedicated to the display and audio (GPU).
The following sequence of diagrams demonstrates the multiplexing of the CPU (shown in blue) and GPU (shown in red). In this example the GPU is operating in text mode and the CPU is executing the sequence described in the numbered list above.
In the first cycle the GPU reads the ASCII code point of a character from the RAM and stores the result in the GPU Cache (gc). The CPU addresses the ROM using the Program Counter (PC) and Page Register (Pg) to load the Instruction Register (I).
In the next cycle the context switches over and the CPU X and Y registers are used to address the RAM and load the CPU Cache (cc). Meanwhile the gc, along with the Scan Counter (SC), is used to address the ROM and load a character bitmap line in to the Glyph Register (G)
The GPU returns to the RAM where the H counter was moved to the next byte and loads the gc with text color values. The ROM is now configured as an ALU with a function specified in the instruction. The cc is combined with one half of the HL register and the result is stored in the Accumulator (A).
In the final cycle the value in A is written to the RAM. The font colors stored in gc are moved to the RAMDAC (C) and the bitmap loaded in to a shift register to start the next character render cycle.
Note: 8-bit ALU functions repeat the last two cycles to combine both halves of the HL register in to a single 8-bit result.
