This device has to do with the way the coil is wound and causing the electricity within the wire to oscillate an electromagnetic field, as well as the neodymium magnets arrangement, with the polarity of the magnets in mind and in a fashion so that the magnetic field collapses into it self, from observation of this device the magnetic flux actually gets stronger and stronger over time. the condensing of the magnetic flux it self, probably due to a vortex of magnetic flux and the way that the electrolytic capacitor\condenser is designed. their is one more thing that i must bring into concept; as there is an electrostatic charge present near the oscillation of the magnetic flux and that is ware what i feel is a valence electron, or particle is set into motion, basically putting static electricity into motion within space. however, now that i think of it perhaps this device is an electron accelerator. all i can say is that over time the magnetic field is accelerating and what looks like to be something similar to a mirage, or a heat wave that can be seen from a far on a hot day. this device is emitting what looks to be a stand alone electromagnetic field, either that or the centrifugal force of the magnetic flux is causing the flux to spin off an electron or electrostatic charge.
A self contained unit
