RPUpi - a shield for Pi Zero and RS-422 over CAT5
Shield for RS-422 over CAT5 with a Pi Zero host
This Shield connects a Pi Zero host to RS-422. It has two RJ45 for daisy-chain and a bus manager for transceiver control.
A Pi Zero can install the AVR toolchain with "sudo apt-get install gcc-avr binutils-avr gdb-avr avr-libc avrdude". I also put Samba on the Pi so that I can edit my project files from a Windows computer that has some good displays. To compile the Makefile is run over an SSH connection.
  • ^3 SPI Interface
    ronald.sutherland08/24/2017 at 06:16 0 comments
    Firmware SpiSlv is used to enable the SPI port on a RPUno (ATmega328p).
    After loading the firmware on an RPUno and enabling the AVR's SPI I next need the Raspberry Pi SPI hardware setup. Raspian needs its interface master driver enabled (e.g. raspi-config).
    Raspibin has an spi group setup in /etc/udev/rules.d/99-com.rules. So I can add my user name to that group for the system to allow me to use the interface.
    sudo usermod -a -G spi rsutherland
    # logout for the change to take
    Next I compile and run spidev_test.c on the Pi with:
    wget https://raw.githubusercontent.com/raspberrypi/linux/rpi-3.10.y/Documentation/spi/spidev_test.c
    gcc -o spidev_test spidev_test.c
    # run with
    ./spidev_test -s 100000 -D /dev/spidev0.0
    ./spidev_test -s 500000 -D /dev/spidev0.0
    ./spidev_test -s 1000000 -D /dev/spidev0.0
    ./spidev_test -s 2000000 -D /dev/spidev0.0
    spi mode: 0
    bits per word: 8
    max speed: 500000 Hz (500 KHz)
    0D FF FF FF FF FF
    FF 40 00 00 00 00
    95 FF FF FF FF FF
    FF FF FF FF FF FF
    FF FF FF FF FF FF
    FF DE AD BE EF BA
    AD F0
    Note: The output is offset a byte since it was sent back from the AVR. I see errors at 1MHz and 2MHz. The RPUpi^3 has a 74LVC07 buffer that pulls down through a 10kOhm resistor on SCK and MOSI. The circuit between that resistor and the AVR has some capacitance which will limit the speed (if there is a need for higher speed it may be possible to swap in a 1k resistor).
    SPI Evaluation
  • ^3 Bootload Remote AVR
    ronald.sutherland08/24/2017 at 06:12 0 comments
    Bootload Remote AVR
    The hostname of the Pi Zero is pi3, it was the third Pi Zero I have setup (it is a bad hostname). The default bootload address on the RPUftdi (e.g. my multi-drop RS-422 board) is '0', and I have not changed it, I keep the i2c-debug firmware on an ATmega328p board under the RPUftdi for use on my test bench, so I will just upload that same program compiled from the Pi Zero.
    rsutherland@pi3:~/Samba/RPUno/i2c-debug $ uname -a
    Linux pi3 4.9.41+ #1023 Tue Aug 8 15:47:12 BST 2017 armv6l GNU/Linux
    rsutherland@pi3:~/Samba/RPUno/i2c-debug $ make bootload
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o main.o main.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o i2c-scan.o i2c-scan.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o i2c-cmd.o i2c-cmd.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o ../Uart/id.o ../Uart/id.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o ../lib/timers.o ../lib/timers.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o ../lib/uart.o ../lib/uart.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o ../lib/twi.o ../lib/twi.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o ../lib/rpu_mgr.o ../lib/rpu_mgr.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o ../lib/adc.o ../lib/adc.c
    avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections  -DF_CPU=16000000UL   -DBAUD=38400UL -I.  -mmcu=atmega328p -c -o ../lib/parse.o ../lib/parse.c
    avr-gcc -Wl,-Map,I2c-debug.map  -Wl,--gc-sections  -mmcu=atmega328p main.o i2c-scan.o i2c-cmd.o ../Uart/id.o ../lib/timers.o ../lib/uart.o ../lib/twi.o ../lib/rpu_mgr.o ../lib/adc.o ../lib/parse.o -o I2c-debug.elf
    avr-size -C --mcu=atmega328p I2c-debug.elf
    AVR Memory Usage
    Device: atmega328p
    Program:    8684 bytes (26.5% Full)
    (.text + .data + .bootloader)
    Data:        375 bytes (18.3% Full)
    (.data + .bss + .noinit)
    rm -f I2c-debug.o main.o i2c-scan.o i2c-cmd.o ../Uart/id.o ../lib/timers.o ../lib/uart.o ../lib/twi.o ../lib/rpu_mgr.o ../lib/adc.o ../lib/parse.o
    avr-objcopy -j .text -j .data -O ihex I2c-debug.elf I2c-debug.hex
    rm -f I2c-debug.elf
    avrdude -v -p atmega328p -c arduino -P /dev/ttyAMA0 -b 115200 -U flash:w:I2c-debug.hex
    avrdude: Version 6.1, compiled on Jul  7 2015 at 10:29:47         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/         Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "/etc/avrdude.conf"         User configuration file is "/home/rsutherland/.avrduderc"         User configuration file does not exist or is not a regular file, skipping
             Using Port                    : /dev/ttyAMA0         Using Programmer              : arduino         Overriding Baud Rate          : 115200         AVR Part                      : ATmega328P         Chip Erase delay              : 9000 us         PAGEL                         : PD7         BS2                           : PC2         RESET disposition             : dedicated         RETRY pulse                   : SCK         serial program mode           : yes         parallel program mode         : yes         Timeout                       : 200         StabDelay                     : 100         CmdexeDelay                   : 25         SyncLoops                     : 32         ByteDelay                     : 0         PollIndex                     : 3         PollValue                     : 0x53         Memory Detail                 :
     Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0...
  • ^2 Board Arrived
    ronald.sutherland06/04/2017 at 04:02 0 comments
    OSHPark did a great job as always, unfortunately, I had a brain fart and forgot that the AVR microcontroller under the shield connects to the RS-422 transceiver through the 74LVC07 buffers I used. I was trying to use the buffers IOFF state to allow the Pi Zero to be powered off without pulling down the RS-422 bus.
    When U3 (74LVC07) does not have power the serial RX and TX from shield can not reach the RS-422 transceivers.
    For testing, I need to cut U3 power from the PI3V3 node and bridge it to the +3V3 node.
    Power RS-422 Buffer
    So far this hack is working, but I have another board on the way so this will soon be back on a spin loop thread.
View all 3 project logs
ronald.sutherland wrote 06/08/2017 at 20:58 point
It helps to be able to iterate the board. Mistakes can be made and the cost is not that painful. I don't even do projects on prototype boards nowadays (but still doing test setups with them).
oshpark wrote 06/08/2017 at 20:34 point
Great idea!
