^2 Board Arrived
A project log for RPUpi - a shield for tool-chain at network edge
Connects a Raspberry Pi to a serial multi-drop bus.
ronaldsutherlandronald.sutherland 06/04/2017 at 04:020 Comments
OSHPark did a great job as always, unfortunately, I had a brain fart and forgot that the AVR microcontroller under the shield connects to the RS-422 transceiver through the 74LVC07 buffers I used. I was trying to use the buffers IOFF state to allow the Pi Zero to be powered off without pulling down the RS-422 bus.
When U3 (74LVC07) does not have power the serial RX and TX from shield can not reach the RS-422 transceivers.
For testing, I need to cut U3 power from the PI3V3 node and bridge it to the +3V3 node.
Power RS-422 Buffer
So far this hack is working, but I have another board on the way so this will soon be back on a spin loop thread.
